lcd picture faded to black
  • attenuator1222
    • 12
    i got the tcon board on my desk in front of me now
    ive just ordered a new identical one off ebay
    http://s14.postimage.org/6oedtkwi9/tcon.jpg
    just for the hell of it are there any tests i can do on this board to find out what went wrong?
    thanks
    i checked the fuse and its fine ,zero ohm
    i was watching tv and the image slowly started to fade to black
    i can see the backlight and audiio is fine
  • randtek
    • Oct 2011
    • 280
    • US
    Re: lcd picture faded to black
    Other than measuring the values of resistors, checking diodes for shorts etc., no there is no way to diagnose. I have not seen any panel manufacturer even release schematics of a T-Con board. Even with schematics, you would need to be able to power up the board and supply LVDS data to it to be able to test any of the integrated circuits.
    • selldoor
      Slow Learner
      • 7870
      Why did you think the tcon was the problem?
      Welcome to the forum-
      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...7&d=1280167246
      https://www.badcaps.net/forum/attach...6&d=1280167246
      https://www.badcaps.net/forum/attach...4&d=1280167246
      It will be useful if you can say a bit about yourself - skills tools etc.
      • attenuator1222
        • 12
        i assumed it was the tcon from what i have read from other forums
        im uploading photos now
        so it could easily be something else?
        i have some tools no scope an hnc in electronics
        • gilly1984
          • 751
          Did you check the voltage to the tcon? Could be bad cap on psu.
          Do NOT touch heatsinks when testing for voltages as they may be LIVE!
          • drpj23
            • May 2012
            • 528
            As long as the voltages check out going to the TCON this could be a heat related problem and freeze/dust spray could find the faulty component(s) on that board (granted it is that board).
            • attenuator1222
              • 12
              here are some snaps
              so you think i was rash in ordering the tcon board?
              • attenuator1222
                • 12
                what kind of voltage level am i looking for?
                • selldoor
                  Slow Learner
                  • 7870
                  Cant quite read is the fuse rated for 32v? Board voltage is usually 12 or 24.
                  set your meter on 200vDC
                  • selldoor
                    Slow Learner
                    • 7870
                    Pictures are too fuzzy for troubleshooting. Probably need to be better lit but without flash.
                    • attenuator1222
                      • 12
                      yes it is
                      i took 2 measurements of just over 5v from either sides of the fuse and the metal chassis with the tv powered on
                      • selldoor
                        Slow Learner
                        • 7870
                        What is the part number on the Tcon board
                        • attenuator1222
                          • 12
                          what is the part number on the tcon board
                          cpwbx3919tp
                          • gilly1984
                            • 751
                            Originally posted by attenuator1222
                            yes it is
                            did You measure after it fades too?
                            • attenuator1222
                              • 12
                              sorry i dont follow
                              the tv faded to black one day while i was watching it (sound still there)
                              now when i turn it on i get the glow from the backlight and sound
                              the measurements i took were with the tv powered on with the backlight glowing
                                • 12276
                                • U.S.
                                sounds like a bad inverter.
                                • attenuator1222
                                  • 12
                                  its not the backlight is working
                                  • gilly1984
                                    • 751
                                    Ah sorry, i read it wrong.
                                    Just found this via a google search
                                    "One trick to check most TCONS for functionality is to loosen the LVDS connector at the TCON (as shown InFigure 3) while the unit is turned on. Handle the LVDS connector with care and be certain to fully release the locktabs. Gently rock the cable in and out of the connector while observing the screen for any response. Dependingon the chassis, the symptoms of the screen may be gentle white flashes, intermittent colored lines, or a screenfull of random patterns. The idea at this point is to provoke some kind of response on the screen. TCON boardsthat have failed will not usually generate any type of response on the screen."
                                    Worth a try.
                                    • attenuator1222
                                      • 12
                                      Worth a try.
                                      hi should of mentioned i tried that as well no change
                                      ive already ordered the replacement now just my luck it wont be the tcon in which case i will skip tv
                                        • 12276
                                        • U.S.
                                        my bad, read it wrong, I thought it read went completely black, gilly is right if no light reaction when tcon is rocked, then more than likely the tcon or tcon cable.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
