vizio vp50
Re: vizio vp50
If there's excessive parallel load, or if the pot is damaged, you could see those readings.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: vizio vp50
Definitely a place to consider. I'd order a compatible replacement & see if it goes.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
tryng to test pots in breadboard can't get readings on either one...?
but safe to assume i am doing it wrong...Last edited by heavymachines; 01-20-2013, 07:38 PM.Comment
Re: vizio vp50
okay got it figured...both pots adjust and no infinite reading in breadboard works perfect far as i can tell so double confirmed ...guess i will have to wait till tomorrow to do power test on tl431...Comment
Re: vizio vp50
UPDATE::::
ok still low VA still at 14 volts and has different TL431 and measurement at,
TL431 pin 1 and 3 is 26.6 volts at location U531 on pcbComment
Re: vizio vp50
There might be a problem around the feedback area of the TL431 and potentiometer.
But I don't know...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
Bummer ....that don't sound very confident...umm there is got to be a silly reason why there is low va..... you say feedback area... do you happen to have schematic's on this beast? i have had no luck just owner's manual just about useless...not ready to give up on it yet...power boards too expensive...
does the TL431 sound high on voltage? er close to the limit of it's capacity..Comment
Re: vizio vp50
No schematics as far as I am aware. The part # is LJ44-00132A right?
The feedback is the signal sent back to the SMPS controller to regulate the output. For some reason it's coming out low or the controller is interpreting it as low. Normally I'd have a board in front of me to diagnose, pretty hard to do it over the 'net.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
(Samsung PSPF561A01A)
the set full model number is VP50-HDTV20A
well now that i figured out macros on that camera i can get better pictures for you if you need...Thanks for sticking it out with me i understand your frustration not having it in front of you...i will do what i can to ease that pain...take better pic's and try by best to fallow instructions... and do some research on my end which i have been doing ....
0Comment
Re: vizio vp50
I'm going to go out on a limb and suggest swapping the Vs and Va pots; see if the problem then moves to Vs. The circuits for both will be similar; the only real difference is one is 200V and the other is 60V, so try and see if there are any obvious differences between the parts: burn marks etc.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: vizio vp50
just so you know i had both pots out and put in breadboard and both read 0.00 one way and approx 25 ohm other way both were within 1 ohm of each other...but still will do pot swap if you insist...Comment
Re: vizio vp50
:close.. it's LJ44-00132B
Sometimes you can find another tv with a simular board.
0Repaired: LG50PQ6000Comment
Re: vizio vp50
this thread says a Sanyo DP50747 (Chassis P50747-00) uses the same power board does the sanyo manual have a psu diagram in?
https://www.badcaps.net/forum/showthread.php?t=11682Comment
Re: vizio vp50
This is weird I just posted this thread:
https://www.badcaps.net/forum/showthread.php?t=25766Comment
Re: vizio vp50
and led does not blink at all on ps, i suppose i could take that jumper off... i will tinker with it more on next sunrise..and re read voltages etc...i have a feeling there may be more wrong with the set...but will git-r-done.Comment
Re: vizio vp50
And thanks for the suggestions gives me lil more leads one of the post i already seen...but as they say anything is better then nothing..Comment
Re: vizio vp50
Man i am such an idiot...
va is fine mistaken it for vg duhh,,,, yes tom do yell i deserve it...
anyways latest update i removed upper buffer and now the set turns on only bottom half screen lights up can't see the menu to switch input to hdmi , put the buffer back in and no dice and those pair of resisters tom we looked at earlier started smoking!!!!!
turned the set off i remeasured those resistors and it still shows 5.5 to 5.6 ohms those are some tough resistors...and removed upper once again and bottom half of screen lights up still... so
most likely dumb question but if i buy a upper buffer is there anything in the y-sustin that could take out the replacement upper buffer? should i check the y-sustin for issues?
my guess would be if it lights up y-sustin is ok most likely but i could be thinking like an idiot again ....???Comment
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by MisterAILHi everyone,
Brought a non functionnal PS5. Apparently only a bad PSU...
No beep, nothing.
After some tests i found this :
- PSU is fine (12 volts stable)
- 12 volts line is shorted
- DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
- By the way, nothing change. No signal, no power, no beep.
Mesuring all rails with my workbench psu (12 volts input)
- 0.00 amp drawing
- 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...5 Photos -
by McfeetroyGood day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
Assuming...7 Photos - Loading...
