vizio vp50
    Re: vizio vp50
    So you changed your meter battery and it reads different?
    • heavymachines
      • Mar 2011
      • 1028
      Re: vizio vp50
      and with old worn battery 7.65 volt output and on breadboard i get 4.28 volts....
      and before battery change it read 4.10 volts what gives?
        Re: vizio vp50
        You should be changing your multimeter battery not TL431 supply.
        • heavymachines
          • Mar 2011
          • 1028
          Re: vizio vp50
          i put the old worn battery 7.65 output back on it and it read 4.28 ....
          i bought 2 new 9 volts and changed dmm..of course i changed it's battery lol..
          • heavymachines
            • Mar 2011
            • 1028
            Re: vizio vp50
            and i put the old worn out 9 volt battery back on the breadboard tested with old and new battery sorry if i threw confusion ....
              Re: vizio vp50
              I cannot explain your readings. You should be seeing 2.495V with 2% tolerance. What are you seeing between ref and anode i.e. 1 and 2.
              • heavymachines
                • Mar 2011
                • 1028
                Re: vizio vp50
                reading -2.50v
                negative probe on pin1 ref
                positive probe on pin 2 anode
                • heavymachines
                  • Mar 2011
                  • 1028
                  Re: vizio vp50
                  i think that might be the answer your looking for if i switch the probe i get 02.5v pin 1 and 2 but it a wild guess on my part...
                    Re: vizio vp50
                    It looks better but with that configuration you should get Vka = Vref (i.e. they should measure the same.)
                    • heavymachines
                      • Mar 2011
                      • 1028
                      Re: vizio vp50
                      well idk....
                      up for any ideas to try.....
                      otherwise i guess we can wait till i get back to work and run jumper wires from pin 1 and 3 from back side of ps and take readings....
                        Re: vizio vp50
                        I'm thinking it's probably OK but there's another problem elsewhere. Put it back in the set. Any way at all to do some in circuit tests of it?
                        • heavymachines
                          • Mar 2011
                          • 1028
                          Re: vizio vp50
                          not till tomorrow....but up for experimenting....
                          try another component in ps?
                          • heavymachines
                            • Mar 2011
                            • 1028
                            Re: vizio vp50
                            i will put a different TL431 back in to rule out original....now that i figured out macros on the camera could get better pic if you would like to get better look...
                            • heavymachines
                              • Mar 2011
                              • 1028
                              Re: vizio vp50
                              what are the other possibilities on this power supply that could cause low VA voltage?
                                Re: vizio vp50
                                Bad adjustment pot is one possibility.
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  Re: vizio vp50
                                  how to test that? use dmm and turn pot to see if ohms change?
                                    Re: vizio vp50
                                    That's one test also it may say something like B100K on it which indicates resistance between two outer pins.
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      Re: vizio vp50
                                      okay one way till stop reads 0.00 ohms
                                      as i turn it climbs to 15.0 ohms then climbs slowly to infinite.. (in circuit test) it an 3 pin device i used 2 outer pins for measurement...
                                      the pot number i can see on top is 3962.....
                                        Re: vizio vp50
                                        It shouldn't climb to infinite; make sure your meter is set on 200kohm range.
                                        • heavymachines
                                          • Mar 2011
                                          • 1028
                                          Re: vizio vp50
                                          how did i know you were gonna say that LOL? yes it was 200k ohm range
                                          say if its a 100k pot shouldn't it range from 0.00 to 100k?
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
