vizio vp50
    Re: vizio vp50
    Originally posted by heavymachines View Post
    more
    whoa somehow that one got messed up
      Re: vizio vp50
      here is whole board hopefully decent enough
        Re: vizio vp50
        That one which got messed up, can you try uploading it again as it looked to highlight the right places, the JPEG probably got corrupted somehow.
          Re: vizio vp50
          post #38 is same pic i pointed out where the VA ADJ pot and KA431AZ is and post #42 is pic of whole board to assist where everything is...
            Re: vizio vp50
            Do you have one with the highlighting or can you do it again.
              Re: vizio vp50
              i deleted it because it was corrpted however i will take more pics for you
                Re: vizio vp50
                here they are let me know if you need other areas
                  Re: vizio vp50
                  okay what did i do wrong for no response lol
                    Re: vizio vp50
                    Patience, I was busy.
                    Where is the Va & 431 device, please highlight them, so I can figure out if they are connected.
                      Re: vizio vp50
                      Post#38 has your answer,, I know you were busy i was just poking at ya playing called sense of humor.... i was lol-ing
                        Re: vizio vp50
                        Ah now I see it.
                        See attached. Is this a 431 device?
                          Re: vizio vp50
                          Ah now I see it.
                          Darn sure enough it is ....it's located between 2 heat sinks and had a film type capacitor covering it..just so you know there is no way in heck i can do a live voltage test on it it way way to tight in there will have to use a needle nose pliers to desoldier it very tight..umm can i do a basic regulator test with it?
                            Re: vizio vp50
                            Can't you solder wires to it? On the bottom of the board, perhaps?
                            We need to measure it in circuit.
                              Re: vizio vp50
                              ha should have thought of that duhhh , did something similar with a crappy salvania tv worst set i ever worked on...fixed it with a new "used" inverter lasted about a month came back with a crack about 6 inches long on the inverter pcb and i just junked it lol P.O.S anyways yeah i will do that another day the set is at work i am at home now just have the boards with me ..so there ain't a effective test i can do on the bench? like desoldier it and charge and discharge it or something?
                                Re: vizio vp50
                                okay i take that as a no...okay i will see what i can do.....
                                  Re: vizio vp50
                                  I'm not available 24/7. If you look in the datasheet there are some example test circuits for the 431 shunt regulator.
                                    Re: vizio vp50
                                    kk i understand will research ...
                                      Re: vizio vp50
                                      k found how to guide looks like i have to get a analog meter...all i got is digital soooo i will seek for one...thanks for all the help i will report back and i have some old power boards around with same type shunt regulator made by a different company but should work if this one is bad...
                                        Re: vizio vp50
                                        No need for analog meter. You can do it with digital meter.
                                          Re: vizio vp50
                                          ok i think my dmm is going wonky getting inconsistent results on the ohm range i don't have 10k ohm range do have 20k i will need to get another dmm to confirm this....but anyways this test was done with analog http://www.jestineyong.com/how-to-te...gulator-tl431/
                                          hopefully none offended for the link, anyways my meter is elenco m-2665 and i think its going out,,, gonna try to get another meter see if i can get consistent results,...
