vizio vp50
  • heavymachines
    • Mar 2011
    • 1028
    Re: vizio vp50
    Originally posted by heavymachines
    more
    whoa somehow that one got messed up
    • heavymachines
      • Mar 2011
      • 1028
      Re: vizio vp50
      here is whole board hopefully decent enough
        Re: vizio vp50
        That one which got messed up, can you try uploading it again as it looked to highlight the right places, the JPEG probably got corrupted somehow.
        • heavymachines
          • Mar 2011
          • 1028
          Re: vizio vp50
          post #38 is same pic i pointed out where the VA ADJ pot and KA431AZ is and post #42 is pic of whole board to assist where everything is...
            Re: vizio vp50
            Do you have one with the highlighting or can you do it again.
            • heavymachines
              • Mar 2011
              • 1028
              Re: vizio vp50
              i deleted it because it was corrpted however i will take more pics for you
              • heavymachines
                • Mar 2011
                • 1028
                Re: vizio vp50
                here they are let me know if you need other areas
                • heavymachines
                  • Mar 2011
                  • 1028
                  Re: vizio vp50
                  okay what did i do wrong for no response lol
                    Re: vizio vp50
                    Patience, I was busy.
                    Where is the Va & 431 device, please highlight them, so I can figure out if they are connected.
                    • heavymachines
                      • Mar 2011
                      • 1028
                      Re: vizio vp50
                      Post#38 has your answer,, I know you were busy i was just poking at ya playing called sense of humor.... i was lol-ing
                        Re: vizio vp50
                        Ah now I see it.
                        See attached. Is this a 431 device?
                        • heavymachines
                          • Mar 2011
                          • 1028
                          Re: vizio vp50
                          Ah now I see it.
                          Darn sure enough it is ....it's located between 2 heat sinks and had a film type capacitor covering it..just so you know there is no way in heck i can do a live voltage test on it it way way to tight in there will have to use a needle nose pliers to desoldier it very tight..umm can i do a basic regulator test with it?
                            Re: vizio vp50
                            Can't you solder wires to it? On the bottom of the board, perhaps?
                            We need to measure it in circuit.
                            • heavymachines
                              • Mar 2011
                              • 1028
                              Re: vizio vp50
                              ha should have thought of that duhhh , did something similar with a crappy salvania tv worst set i ever worked on...fixed it with a new "used" inverter lasted about a month came back with a crack about 6 inches long on the inverter pcb and i just junked it lol P.O.S anyways yeah i will do that another day the set is at work i am at home now just have the boards with me ..so there ain't a effective test i can do on the bench? like desoldier it and charge and discharge it or something?
                              • heavymachines
                                • Mar 2011
                                • 1028
                                Re: vizio vp50
                                okay i take that as a no...okay i will see what i can do.....
                                  Re: vizio vp50
                                  I'm not available 24/7. If you look in the datasheet there are some example test circuits for the 431 shunt regulator.
                                  • heavymachines
                                    • Mar 2011
                                    • 1028
                                    Re: vizio vp50
                                    kk i understand will research ...
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      Re: vizio vp50
                                      k found how to guide looks like i have to get a analog meter...all i got is digital soooo i will seek for one...thanks for all the help i will report back and i have some old power boards around with same type shunt regulator made by a different company but should work if this one is bad...
                                        Re: vizio vp50
                                        No need for analog meter. You can do it with digital meter.
                                        • heavymachines
                                          • Mar 2011
                                          • 1028
                                          Re: vizio vp50
                                          ok i think my dmm is going wonky getting inconsistent results on the ohm range i don't have 10k ohm range do have 20k i will need to get another dmm to confirm this....but anyways this test was done with analog http://www.jestineyong.com/how-to-te...gulator-tl431/
                                          hopefully none offended for the link, anyways my meter is elenco m-2665 and i think its going out,,, gonna try to get another meter see if i can get consistent results,...
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
                                          • howardc64
                                            Vizio SmartCast TV software bug that looks like hardware
                                            by howardc64
                                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                            11-16-2024, 05:17 PM
