SAMSUNG PN50B450B1 - Vertical Section missing, lines
  • dotcalminc
    • 28
    Hi. Attached are pictures of my issue. The large section missing in the middle shrinks after about 30 minutes of watching tv, but is obviously still noticeable since it's smack in the middle of the screen. As you can also see, there are single vertical strands of red, green or blue along the right side along with the white strip.
    Thanks for you help and insight.
    Re: SAMSUNG PN50B450B1 - Vertical Section missing, lines
    This is unfortunately a bad plasma panel and not repairable.
    Samsung has a known issue with this 50" (B450/C450) having stuck lines, call them up.
    Someone swapping panel, warranty repair: https://www.youtube.com/watch?v=Mq1j-G7slqQ
    • RJARRRPCGP
      • Jul 2004
      • 6304
      OT, on my laptop LCD screen, I have what looks like that, but there's not a thick black line and it appears to be bad T-con contacts. When I flex it a certain way, all the vertical lines go away!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • dotcalminc
        • 28
        Thanks Tom! I hate to hear that, but I guess I'll just have to keep using it as is. Like I said, After the tv warms up for about 15-30 mins, the large section in the middle shrinks to about the same size as the white line on the far right.
        I appreciate all you guys do, not just for me, but everyone here!
          How old are you?
          It is a well known issue and I heard Samsung sometimes offer warranty extensions if you push them.
          • dotcalminc
            • 28
            30. Why do you ask?
              Sorry!
              I am too tired to type. I mean hold old is the set? Lol. :P
              • dotcalminc
                • 28
                lol.
                The born on date is July 2009.
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • x_orange90_x
                  Samsung UN46C8000XFXZA vertical bars/horizontal lines
                  by x_orange90_x
                  I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                  The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                  09-04-2023, 12:09 PM
                • polaro
                  Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                  by polaro
                  Greetings,
                  I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                  08-27-2022, 08:46 AM
                  09-07-2024, 05:50 AM
                • Anonmis
                  Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                  by Anonmis
                  Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                  The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                  12-01-2023, 04:31 PM
