Vizio VL320M Screen
  • mhen415884
    Vizio VL320M Screen
    I'm new to Badcaps, seeking advice. My brother just gave me a Vizio VL320M. He was in the process of moving and said something fell against the screen and now the picture is all messed up. The actual screen face is not cracked or broken anywhere i can see or feel.
    Is there any hope to recover the screen or has it actually broken the lcd filament beneath the glass/plexiglass.
    I can see where there's a spot in the lower right side that has a burst of colors around a spot that looks like something pointed has hit the screen like a window that's had a BB shot through it.
    Re: Vizio VL320M Screen
    The LCD is ruined; the TV is worth only parts now, if you are willing to strip it down.
    It's not repairable.
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • paqman
      Vizio M60-C3 black screen
      by paqman
      So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
      So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
      03-02-2024, 04:37 PM
