Westinghouse 42 " stuck in standby
+ More Options
Posts
  • bobbyd40
    • Dec 2012
    • 116
    • usa
    Hi picked up a Westinghouse TX-42F3MUT.powers on with no start up screen led flashes blue for a instant and goes to red.
    I read the post about the firmware flash i have done that and it came on and worked fine until it sits over night and goes back to standby.
    Do you think it has another problem or the flash is just not taking?
    Re: Westinghouse 42 " stuck in standby
    Make sure it is not set up in SHOP MODE.
    This resets settings to default after a predefined time, for use in retail shops where customers fiddle with the TV.
    To leave shop mode do a factory reset then when it prompts you select "Home Use", then do the firmware flash.
    This TV may not have shop mode but I encountered a similar issue with a Samsung LCD being set to shop mode.
    • bobbyd40
      • Dec 2012
      • 116
      • usa
      Thanks Tom will give that a try.
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
      • toty79
        Hisense LTDN50K220WSEU stuck in standby
        by toty79
        Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
        As per Hisense tv title LTDN50K220WSEU stuck in standby
        PSU rsag.820.5687 HLL 4855WF
        Main rsag 7.820.5842
        I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
        05-01-2022, 04:39 PM
      • lego1234567
        LG 32LB1R - stuck in standby mode
        by lego1234567
        Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
        What could be the problem ? Thanks...
        01-21-2024, 03:39 AM
      • Stunt
        Hp Laptop Stuck on Hp protected by hp sure start screen
        by Stunt
        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
        screen that's it and stuck there. I left it until the following day and i still...
        09-02-2025, 01:51 PM
      • Rusenga
        Samsung UA39EH5003R Stuck on standby
        by Rusenga
        Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
        Connector CNM803:
        TV ON
        Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
        TV OFF
        Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
        09-18-2021, 11:51 AM
