samsung ln46c610
  • mrcooperdog
    anyone can
    • 8
    • U.S.A.
    samsung ln46c610
    Hi everyone, i have a Samsung 46ln46c610. I lost picture on it, but still have the sound. I narrowed it down to the power inverter board. from there i narrowed it down to a capacitor(i think). it is a little gray rectangle that says, 2w 474k. below that it says sic 460s. after both of those, there is a line and then the number 10, over the number 21. i have found that it is labeled cl818 on the board. this is the same amongst other Samsung boards. i found another board not from my tv that had same part labeled under the cl818. reading through the threads i found someone who found the part number as C-AL;1uF,20%,250V,GP,TP,6.3x11,5. where can i find this part!!!!! mouser and digikeydid not have it nor did any of the usual suspects. my feelings are repair shops have to be able to get this right? i have included a picture of it. thanks, Steve
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: samsung ln46c610
    Moved from FAQ. Please do not post questions there.
    sigpic
    (Insert witty quote here)
      Possible substitutions:
      http://www.digikey.com/scripts/dksea...ity=0&PV13=253
      Select the one which fits the dimensions.
      • mrcooperdog
        anyone can
        • 8
        • U.S.A.
        awesome, thanks. Ill also take that as a you have no idea what or how to fix this. thanks. Im sure someone with at least bare minimal knowledge of electronics on this site will be able to help me. cant all know what were talking about i guess!!!
          Umm, I am quite knowledgeable. I have replaced several similar capacitors in LCD TVs before. Unfortunately, I do not yet have the ability to measure the spacing beween the leads under a capacitor via my x-ray vision, but I am working on it. (I can do it within 1 inch of the board but not yet over a photo.) I estimate the capacitor to be about three-sevenths thumbwidth across and four-thirds thumbwidth along.
          • mrcooperdog
            anyone can
            • 8
            • U.S.A.
            sorry, was not directed towards you tom. you do come across very knowledgeable.... a little to much. am pretty lost looking on mouser. new to the site and did not like the way ratdud4747 answered the post. very negative. i am not gonna give him the pleasure of making me feel stupid. i do like your sense of humor. is that a left or right thumb?!
              Ratdude747 moderates this forum; it's his job (although he is unpaid) to make sure the forum stays in order. FAQ forum is for regular questions (e.g. how do I solder, how to attach post, etc.), TV forum is for stuff like this. Have a little more respect for our moderators.
              Important thing about thumbwidth is that it depends on which quantum plane you observe it in because it can be either, both or none at the same time.
              • mrcooperdog
                anyone can
                • 8
                • U.S.A.
                respect is earned not given. a simple "hey i see your new here, you posted in the wrong place. i moved it for you" would have put me on my nice apologetic side. not trying to piss people off, but not convinced any one can say yes, go to "blank" they have it. do repair shops fix things or just replace with a new board? i have provided as much info as possible
                  I suggest you take up any grevances with the administrator, Topcat. But ratdude was just trying to be helpful.
                  Most repair shops nowadays just swap boards, which is why they cost so much.
                  I gave you a link to replacement parts did I not?
                  You have to do some work here and check the dimensions to see if one will fit.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    i would unsolder it and measure the leg spacing with a small ruler you could probably do this whilst its still on the board but some of the various capacitors can hold a charge even though the sets turned off so be careful.
                      "i found someone who found the part number as C-AL;1uF,20%,250V,GP,TP,6.3x11,5."
                      Form the picture (474K = 0.47uf 10% tolerance) that you have posted on post1, that cap is 0.47uF not 1uF.
                      Are there any printings on the side of the cap at all? It has bulginf from the side, so it is bad cap.
                      The board looks like SAMSUNG P/N BN44-00341, not sure if Tom has the SCH for it or not.
                      http://www.shopjimmy.com/samsung-bn4...t-inverter.htm
                      • mrcooperdog
                        anyone can
                        • 8
                        • U.S.A.
                        thanks vinceroger69, now were starting to get somewhere. i was under the impression with the part number i would be able to find the replacement part. all i have right now is a standard measure of two cms
                          Possible schematic:
                          http://www.tgohome.com/ServiceManual...&Search=Submit
                          In case it helps.
                          • mrcooperdog
                            anyone can
                            • 8
                            • U.S.A.
                            well budm, you know your Samsung boards! definitely a bn44-00341b, but no printing on the side unfortunately
                              OK, thanks to TOM sch, it is 0.47uf 450V polyester film cap.
                              • mrcooperdog
                                anyone can
                                • 8
                                • U.S.A.
                                thanks to budm and tom. i figured it out how to read every thing after almost an hour. I simply punched in 0.47uf 450V polyester film cap in my search engine and it pulled up element14. THIS COMPANY SELLS BOARD PARTS!!!!. MY CAPACITOR POLY FILM 0.47UF, 450V COAST .50!!!!!!!!!!!!!. i got no where with mouser and digikey. IF YOU NEED SAMSUNG POWER INVERTER BOARD PARTS, GO HERE!!!!!!. THIS WILL, AND CAN SAVE YOU $$$$ Sorry to all those tv repair places for blowing up your non actual fixing racket!!!!!!
                                  Digikey do too.
                                  http://www.digikey.com/product-searc...=0.47uf%20450v
                                    09-07-2024, 05:50 AM
                                    09-06-2024, 11:40 PM
                                    09-06-2024, 08:40 PM
                                    Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                    This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-06-2024, 06:20 PM
