Vizio VW42L HDTV10A - Just replace caps? or test PS?
    Re: Vizio VW42L HDTV10A - Just replace caps? or test PS?
    The caps fail because they are Samwha, in my opinion, second worse cap manufacturer in world, only behind CapXon…
    • LogicalTime
      • 9
      I didn't see the fall. I just got it from a friend and I thought it would be fun to try and get it functional again. I'm an amateur, so I'm going to take small manageable steps for now and work up my skills and toolset to the point where I can keep up a bit better with you guys. I have taken MITx's 6.002 Circuits and Electronics course though. So I have some low level understanding. I'm interested in learning more. :-)
      I ordered the FR caps.
      • LogicalTime
        • 9
        Update!
        I replaced the caps and the tv is working wonderfully! Thanks guys. I added some pics of the replaced caps to the album here is a link:
        Pics from project
          by momaka
          03-12-2025, 03:42 PM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • edith
          Caps and how to find one to replace
          by edith
          Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
          Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
          Thank you!
          06-11-2023, 05:00 PM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
        • Mattz_GT
          Which caps to replace: ECS P4M800Pro-M V1.0A
          by Mattz_GT
          It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
          I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
          Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
          Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
          PS. Additional diagnostic,...
          01-22-2025, 12:12 PM
