Is my newest VCR dying?
  • Tom41
    • Oct 2005
    • 336
    • England
    I've noticed recently that my latest VCR (the replacement for the one with the bulged Panasonic FC cap) has started to show worrying symptoms. It's not taking forever to power up, and doesn't take a while to 'warm up' before the picture stabilises; it's more to do with the mechanics.
    When I play-rewind (scan) a PAL tape that's near the end or near the beginning, the VCR for some reason switches to NTSC playback mode, giving a very distorted and corrupt picture. Upon pressing Play again, it takes about half a second then detects the PAL signal, and switches back to PAL mode.
    Also, I've noticed that when the gears change to go into rewind or fast forward mode, I can hear a sort of 'groaning' noise, and the process of head drum wrap-around seems slower than it was when the VCR was new.
    Opening it up, I found one giant ELNA cap where the mains comes in, and all the rest of the caps are Lelon. There are no visible signs of bulging or venting yet, but could the caps be failing?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Is my newest VCR dying?
    Hm Lelon.. i think they are BS, not seen many cases but i think they are coparable with GSC or Choyo....
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      how old is it? what brand is it?
      some of the newer stuff is so crap anyway.
      • MrCreosote
        2 Belkin KVM switches have dim VGA output
        by MrCreosote
        When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
        4-port Omniview Pro2 f1dz104t
        8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
        The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
        AD ADAPTER:
        There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
        08-15-2023, 08:26 PM
      • _max_
        Hisense H60N5705 automatically switches off
        by _max_
        Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
        Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
        Power cable and HDMI cable checked.
        No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
        So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
        03-07-2025, 06:14 AM
      • wrobbie
        Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
        by wrobbie
        My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
        02-26-2025, 10:02 PM
      • CdDvdFlash
        DSE GE6878 possible TV receiver dying remote not working well
        by CdDvdFlash
        For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
        07-03-2024, 03:55 AM
      • merkin
        help with finding replacement switches
        by merkin
        These switches are bad and I need a replacement.
        The dimension are:
        L: 10mm
        W: 5mm
        H: 4.5mm
        Pins are 5mm center to center both length wise and width wise.
        Any help would be appreciated....
        02-13-2024, 11:31 PM
