Vizio XVT553SV Powers up/audio/no vid.
  • samson7point1@yahoo.com
    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
    by samson7point1@yahoo.com
    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
    The player processes the audio signal using two different reference frequencies. The "R"...
    04-30-2024, 11:22 AM
  • csmith
    Vizio D50u-D1 Powers up no picture
    by csmith
    I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
    Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
    supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
    issue. Set will power up with remote but not power off....
    07-11-2025, 11:52 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • WayOfTheRoad
    Vizio D55x-g1 (55" 4K, no backlight, has Audio and picture)
    by WayOfTheRoad
    Hello, everyone. A neighbor was throwing this TV away for "not turning on" so I asked for it and they gave it to me for free since Vizio gave them a new TV under warranty.
    I'm pretty proficient with electronics in general but this is the first TV I've ever tried to fix. I strongly suspect bad LED lights but figured I'd post some info and see if those of you more experienced with TVs can confirm my suspicion before I move forward. Some photos and measurements below:
    The power supply only has two outputs, one output cable going to the main board and the other...
    03-31-2022, 12:22 AM
  • npolite
    Vizio E320-A1 Powers on But No Display
    by npolite
    Hi All,
    I have a Vizio E320-A1 which lost sound and picture. The power LED comes on and stays on but nothing else works. I am not able to power it off unless I unplug it.
    Here are the voltages when the power is on
    1 - 5.25
    2 - 5.25
    3 - 0
    4 - 4.8
    5 - 25
    6 - 25
    7 - 0
    8 - 0
    9 - 0
    10 - 12
    11 - 12
    12 - .9
    13 - .5
    Can someone let me know if the issue is with the mainboard?
    Thanks...
    04-19-2024, 11:33 AM
