Lines and noise on entire Syncmaster S24B300EL LED. T-con, Panel or...
  • 2andrewd
    • Mar 2012
    • 41
    • us
    Okay as you can see from the photos this one has some real non-sense making it extremely hard to play WOW and mine sweeper or anything at all. The viewing angle vertically is about 5 degrees, it's dim and this pattern is pervasive across the whole screen. The ESR on the caps checked out. I've not tested anything else. Any ideas?
    Re: Lines and noise on entire Syncmaster S24B300EL LED. T-con, Panel or...
    I'd say it's most likely the t-con. But if it's a new LED, the t-con will be integrated onto the panel.
    • 2andrewd
      • Mar 2012
      • 41
      • us
      I imagine it would be possible to pull apart this extra 24" ccfl panel i have sitting here and use it's LCD with the LED's backlighting? they are both 30 pin connectors, i haven't looked at the datasheets yet.. what do you think?
        Worth a shot. For a computer monitor you gain very little from LED backlighting though.
        • 2andrewd
          • Mar 2012
          • 41
          • us
          If i can get 1 working from 2 that don't i'll be happy. would the led logic fire up and let me shine a torch into the ccfl panel to make sure it is going to drive it?
            I wouldn't know, sorry... I'd be surprised if the panels were compatible and changing the backlight may be impossible.
            • 2andrewd
              • Mar 2012
              • 41
              • us
              thanks for the help. i'm leaving everything in the led panel and swapping its lcd with the suspected bad tcon for the other from the ccfl panel.. i'll report back
              • 2andrewd
                • Mar 2012
                • 41
                • us
                Turns out the panels aren't quite correct dimensions. What tcon components should i aim at when troubleshooting?
                • 2andrewd
                  • Mar 2012
                  • 41
                  • us
                  Anybody? It's getting 5 volts from the logic board and the fuse is passing current. Theres a voltage regulator on the t-con outputting 3.3 and some IC's i haven't researched (very detailed description, i know) Has anyone seen/managed to rectify an issue similar to this, if so... what was the nature of the problem? I plugged the logic board into a different panel and the picture was fine so it's definitely t-con/panel related, i just wonder if its a total wash or not.
                  • howardc64
                    by howardc64
                    Yesterday, 05:17 PM
                  • oldmanhouse
                    Panasonic TX-L50B6B | High pitched noise and black lines
                    by oldmanhouse
                    Hi folks, I have an issue with my 7 year old Panasonic TX-L50B6B that has appeared within the last few days.
                    The symptoms are:
                    • A high pitched "buzzing" / "whining" noise coming from the TV when it is turned on. There is no noise during standby, and the noise persists with all AV connections removed.
                    • There are noticable horizontal lines in the picture. Upon closer inspection it looks like every few rows of pixels are dead/black.
                    Attached is a close-up of the picture in "test mode", to demonstrate the rows of black lines.
                    07-09-2020, 06:30 AM
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • tony359
                    by tony359
                    11-28-2023, 05:18 AM
                  • Stanley1843
                    by Stanley1843
                    06-29-2024, 11:54 AM
