55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
Re: 55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
Just ran the tests and both isolations of the SD and the SU boards still resulted in a blinking power light so I guess that means the SD and SU boards are bad?? Is there any change of it being the SS or A as some people have speculated and any tests that can be done to eliminate those before I go ahead and buy both the SD and SU. Again is is safe to assume that if the full isolation let the LED stay on and no flashing that the SC board is actually ok? Really appreciate the support.Comment
One other clarification, assume your confirm that my testing shows the SU and SD are bad. When you remove these, do you take the volume control off and then pull the 5 ribbons per board off? do these just lift off or something special to remove?Comment
I can't help you on that since I didn't have to remove mine, and it's a different model.Comment
tw2005, I followed the isolation and disconnected the SD and SU board then shorted the SC50. The set came on and stayed red LED no flashing only a loud humming. I assume this means it is not the SC but it is the SD or SU then. Can you confirm my understanding. Is there a way to figure out which of these two by isolating one of them at a time with the SC50 shorted and see what the LED does? Appreciate the help.
Not sure about the humming, can't say i ever had that on a SC test unless the board was not screwed down properly.
As far as the buffers tested one at a time, I've never tried that procedure. I'm always hesitant about it in case a bad board blew the SC.
I usually try to check the resistance and for shorts on them.
Must admit I was expecting bad SC but if it turned on, no blinks and the green LED on the board was lit then that does indicate bad buffers.Comment
When I did the test on my "wrong" sc board; it let out a hum. Might be because the power has no where to go.Comment
when you did this did you notice if there was a tiny green LED lit on the SC board?
Ran the test again with SD and SU disconnected from SC with jumper sc50 and I get a green light on the SC board. Do you all think I am safe to assume it is either SU and/or SD at this point? I dont have the voltage equipment to check those. Do you have any reasonable repair place that I can send them and have them fixed and any idea how much if it is both of them?
No you'll have to try and source a good set of buffer boards. If you know someone with a meter we could try and figure out which one is bad but for simplicity just as easy to get both.
Just had a quick look and looks like they're going to be a little rare and expensive, especially the SU.Comment
Found this SU for $54.41: http://tvpartsunlimited.net/shop/lg-...-50pv400-ub-2/
or new for $160: http://panasonic.factoryoutletstore....erm=TXNSU1NVUU
Only found SD new for $160: http://panasonic.factoryoutletstore....erm=TXNSD1PAUUComment
There may be a couple of tiny smd caps missing looking at the photos, chances are it'd work too but it is a different panel number in the GT/VT compared to the ST.Comment
Don't forget he said he had a ST30, not a GT. Not sure what the difference will be for the upper. Looks like they share the SD but some reason they have a different revison number for the upper on the ST30. TXNSU1PAUU
The supplier site shows both sharing the same SD.
Isolating which board is bad would save some cash. If it's only one.Comment
Good catch. I missed that. Only found it new for $160: http://panasonic.factoryoutletstore....erm=TXNSU1PAUU
Normally buffers are a bit easier to find than SC boards but each model seems to have their own weakness.Comment
Thanks again for all the help. If I track down a meter how hard is it to figure out if the SU or SD is the problem? Hate to spend $160 for a board only to find out I dont need it.Comment
Lots of good tips and links to sources for more help.Comment
Just wanted to get some feedback and advice. I reached out to ModusLink and they have a repair program where you send the boards in for repair. Pretty reasonable price. Question is have you heard of others having success with them? They have asked me to send all three boards and not just the SU and SD. Does this make sense given the testing that I shared and you guys have commented on here. If there is nothing wrong with the SC board then they have a test charge of $50. I can get the SC replaced through ShopJimmy for $65. Didnt seem like it made sense to send the SC. Is this required for proper repair?Comment
Hello group,
I have the TCP50GT30, which should be close to same unit, also with 7 blinks. The SC was shorted across SC20. I replaced all six transistors (3 were shorted) but still 7 blinks and SC20 looked shorted again. I sent SC out to a board repair service but want to be extra careful when it comes back. I will isolate from SU and SD by disconnecting and using the jumper as per the manual as a preliminary check that SC is now good. But how do I check the SU and SD without risk of popping the SC again? I saw some resistance values posted for SU and SD for another model. Does anyone have values for SC41, SC42, and SC46 I can compare to? An initial check of each of the pins on these connectors against VFG suggest no shorts. All are either open circuit or at least 1.6 Meg.Comment
Had same 7 blinks of death. Followed the advice of those in the know. Many thanks. SC2 showed a short. Found Q401,402 and 403 obviously shorted. Replaced. Still have same 7 blinks. Again, these IGBT bad. Diagrams unhelpful. Traced and found Q421,422,423 opposite side of circuit through coils at top of board. If one or more are shorted they did not show short at sc2. To be safe and while you are there best to replace all 6. Not sure about the resistors, IC and small driver.
Beside the panasonic numbers, does anyone know the mfr# for IC502 and Q531 as they are too small to read.Comment
CPH5524-TL-E by SANYOComment
by bialagHello,
I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,... -
by AudezeI have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
Does... -
by badcappoHello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
Diode type G972s6 - D101 with a short
Mosfet 06N90E - Q301 shorted
Fuse T5AH 250V - F103 blown
Diode D301 shorted
Relay DG1U-17VDC II - RL001 blown
I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀... -
by domixHello i have 43pus6401/12.
After turn on red light slowly blinking and ambilight blinking randomly, different colors fadein/out, etc
Screen is black, no backlight. Caps look normal. I didnt measure it, I forgot my multimeter in another car.
Any common issue?
Thanks... -
by crewdogBoard DAOP5HMB8F REV F
Model OPSH
No bios battery on board
Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats.... - Loading...
