52LG50 Has Mind of its own
  • Lireb93
    • Dec 2012
    • 20
    Re: 52LG50 Has Mind of its own
    0000 is the factory code and it worked
    • Lireb93
      • Dec 2012
      • 20
      I replaced the Main Board in the set and everything seemed to be fine. Was just like getting a new TV. However, this morning I went to turn it on, and when I hit the remote the TV clicked twice and came on and went off and then came on. What is the problem here? I replaced the the IR sensor(switch), main board, so what else could be causing this? I unplugged and did a factory reset by holding in the on/off switch for about a minute and the sensor light glowed. It is still unplugged and will be for a couple hours before I try it again. Any ideas?????????????//
      • Lireb93
        • Dec 2012
        • 20
        Replaced the Main Board and all was well for a couple days, and then it started on/off ect. Today it comes on and you can't shut it off. Turn it off and it comes back on. Could it be the power cord? It is a little wobbly when installed and it is the right angle plug and not the on that is straight in line with the cord.
        • chicago77
          • Oct 2014
          • 15
          Well I have the same problem and I've read that most people have replaced different boards and it reall has only fixed the issue for a few weeks.
          I have figured out that if I disconnect any one of the 4 connections to the LCD the power stays on or off. So my thought is that something is not able to draw enough power to run all four. Maybe an electrolytic cap is starting to fail and needs to warm up before functioning. I don't have any obvious ones but if they are crapy caps they might be performing just below spec.
          • chicago77
            • Oct 2014
            • 15
            Also does anyone know what the board at the top center of the TV does? I can't get the cover off it currently.
            • fierygt
              • Mar 2013
              • 14
              That is the timing control (t-con) board. It delivers the image to the lcd screen.
              I have this same TV, with this same problem, and can't figure it out. I replaced all the capacitors in the power supply, even the smallest ones, and it made no difference. The original ones didn't even look bad, but I did it anyway. If I unplug the two connections from the PSU to the inverter boards, it will act 'normal', and stay on and turn off like normal, but obviously there is no picture. Another person said it might be in the mainboard, but that doesn't seem right, if when the inverter connections are disconnected, it will power on and off like normal. There are a few capacitors on the inverters themselves, but I have taken off one side's shielding, and they look ok. I have also disconnected the front panel, as part of my process of elimination. I guess I am curious if there is a way to test the inverters or has anybody replaced them with success?
              • gfox
                Elect Eng
                • Apr 2015
                • 10
                Did any of the people who posted on this thread ever figure out what was causing their 52LG50 sets to cycle power, or not go off and stay off?
                I have the same television doing the same thing.
                Thanks!
                • fierygt
                  • Mar 2013
                  • 14
                  There is a 5w 6.8 ohm white ceramic resistor, next to the black relay, near where the 120v line runs into the power supply. Mine is reading around 10 ohms, which assuming it has a 5% tolerance (it doesn't really say on it), would make it well out of spec. I have not yet replaced it, and still need to get one ordered to find out, but that is where I am putting my money at the moment.
                  • gfox
                    Elect Eng
                    • Apr 2015
                    • 10
                    Fierygt,
                    Do you also have a 52LG50 that is doing the same thing?
                    If so, I was wondering if you could do me a favor and try something with yours? The one thing I have noticed is that the television works just fine as long as the back cover is not on. I have removed the cover and replaced it without screws multiple times to watch the problem come and go. To further understand where the plastic cover is effecting the operation I placed the cover just over certain modules on the back of the television. I found that the when the cover is within 6 inches of the Power Supply the problem exist. So at this point to me it seems like there is some EMI or noise issue that causing interference when the cover is within proximity (does not have to be touching).
                    I tried measuring the resistance of the plastic cover thinking maybe it is made out of some conductive plastic, but found nothing.
                    If you could try operating yours with the back cover off I would be interested to see if have the same findings.
                    • fierygt
                      • Mar 2013
                      • 14
                      I have the back cover off mine, right now, and I tried it without it, but it cycles on and off and makes no difference for me.
                      • gfox
                        Elect Eng
                        • Apr 2015
                        • 10
                        WOW! Never mind I could make it come and go 30+ times by removing and replacing the cover the night before last and then last night it was giving me the problem even with the cover off.
                        The 5w 6.8 ohm white ceramic power resistor that you referred to is measuring 7 ohms on mine in the circuit.
                        The thermistor (which resembles a ceramic cap, labeled TH) next to the relay measures about 10 ohms.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4981
                          • New Zealand
                          #32
                          PSU capacitors on the way out, extra power draw from the inverters causes PSU overload and shutdown?
                          -David VanHorn
                          • fierygt
                            • Mar 2013
                            • 14
                            "I replaced all the capacitors in the power supply, even the smallest ones, and it made no difference."
                            I ordered a complete kit of new capacitors for the PSU, even though none of mine looked physically bad, and replaced every electrolytic capacitor on there, besides the two largest ones, and it didn't fix the problem. I've researched the issue in other forums, and others have said they replaced the capacitors too, and it didn't fix this particular problem with this particular tv. Which is why I started looking in other places. I haven't yet ordered the 6.8 ohm resistor replacement to test, just because of priorities, but maybe someone more intelligent than me, can give a defacto answer as to how 'out of spec' that 6.8 ohm ceramic resistor can be. To me, if it's not within a 5% tolerance, that seems bad. It does seem like "something" is drawing extra power, but it must be something besides the PSU electrolytic caps.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4981
                              • New Zealand
                              #34
                              Sorry, guess I didn't read everything! It does sound like you're right about that resistor.
                              Even if it had a huge 20% tolerance (which I doubt) it could only be 8.16 Ohms at the highest and still be in spec. Hopefully it is the cause of the problem.
                              -David VanHorn
                              • gfox
                                Elect Eng
                                • Apr 2015
                                • 10
                                As cheap as the power resistor is it wouldn't be a bad thing to replace it, but I highly doubt that is the problem. Especially since mine measures very close to spec and still has the same issue as yours. I would have to believe the root cause of both of ours will be the same.
                                As I mentioned earlier I did change out both of the larger 220 uF caps, because one of mine was bulged on the top, but it did not help the problem at all.
                                The night before last I took the power supply out again and started looking to see what is driving the small relay on the PS. All I did was take it off and check a few of the diodes around the relay and then put it back. The television turned on and then shut right back off. Now I can't even get the television to turn on at all. I haven't had a chance to really look into it, but my thought is that there is something wrong with the relay itself. I will be checking to see if I am even getting voltage to the relay coil. If there is, I will be taking it off of the board and applying 5 volts to the coil to see if it is still operating properly.
                                I have been an Electrical Engineer for 17 years, (which doesn't make me a television repairman, LOL) and this one has me stumped.
                                I have been refusing to just start swapping out modules, especially since so many people have posted on many sites that they have taken this route and the television only works for a short while, then start acting up again.
                                • gfox
                                  Elect Eng
                                  • Apr 2015
                                  • 10
                                  Fierygt,
                                  I told you that all of a sudden I completely lost power and that my television wouldn't even try to power up. Well, I found the problem I why it won't power up. I lost that power resistor that we have been talking about. I couldn't believe it! Either that is very ironic or that has been a weak link. I never did anything that should have effected that resistor and it has just completely opened up.
                                  I will let you know how things go once I replace it.
                                  Have you replaced yours, yet?
                                    Is this the power supply board you are working on? The OP never provides me the pictures I requested.
                                    http://www.shopjimmy.com/lg-eay41752...wer-supply.htm
                                    • fierygt
                                      • Mar 2013
                                      • 14
                                      budm, Yes, that is the power supply I am working on.
                                      gfox, I haven't even gotten around to ordered it yet, just because of priorities, but I was planning to soon.
                                      • gfox
                                        Elect Eng
                                        • Apr 2015
                                        • 10
                                        fierygt
                                        I just ordered 5 of them, so if it fixes my problem I will let you know. I could stick one in the mail for you also. They were only less than $0.20.
                                        • fierygt
                                          • Mar 2013
                                          • 14
                                          gfox, for sure.
                                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                            12-16-2023, 08:39 PM
                                          • rddube
                                            Lenovo L490 Ram voltage circuit malfunction
                                            by rddube
                                            Hello friends,
                                            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                            07-15-2025, 04:41 PM
                                          • notallbad
                                            TCL 55RP620K power board issue
                                            by notallbad
                                            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                            0% p_dim at 1.65v and a_dim at 1v
                                            50% p_dim at 3.3v and a_dim at 1.65v
                                            100% p_dim at 3.3v and a_dim at 2.88v
                                            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                            Leds are 2 rows of 15 6v leds.
                                            On inspection of the power board found diode MBR3200 shorted so replaced with...
                                            07-12-2025, 05:45 AM
                                          • schematic_jack
                                            ASUS TUF B450-PLUS II motherboard schematics, or does this 60B SMD resistor even matter?
                                            by schematic_jack
                                            I think it would be dumb to toss a "modern" motherboard just because a resistor got scraped off, so here I am. I am hoping to find the right schematic so I can see if the motherboard can live without 1 of 3 60B SMDs in series likely scratched off by the backplate of a PCI-E card install or removal. It could be related to a functionality that is not needed or critical, or it could fry anything I plug into it and power on. If I could find a replacement, I could likely pop in on the board, but if I don't need to, then screw it, I don't mind leaving something dark that doesn't matter....
                                            07-06-2025, 02:00 PM
                                          • JoWed
                                            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                            by JoWed
                                            Hello Community,
                                            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                            07-01-2025, 09:32 AM
