Viero PDP42V18HA short on Z-SUS?
  • gijoey198079
    • Dec 2012
    • 53
    I picked up this 42 plasma from a friend, it would power on, click a few times, power off then back on a second time and click a few times then goes off.
    I found one of the ceramic fuses on the Zsus blown, replaced with same fuse but no change. I then unplugged the zsus from the power supply and now the tv will come on and show video on little more than half the tv but a little dim.
    I assumed the zsus is bad so I pulled it and ran a few checks and both Vs inputs on the board are shorting out to ground. Pulled all capacitors then rechecked board with caps out and still have short.
    I am thinking the ipm is probably toast, any one else have a suggestion, thanks?
    Re: Viero PDP42V18HA short on Z-SUS?
    I would agree with your conclusion. A dim picture means the Y-sustain is likely OK, the Z-sustain needs a repair.
    • gijoey198079
      • Dec 2012
      • 53
      Any advice on removing it? I've done all types of soldering but even hitting this one with 1100 degree heat gun won't loosen the solder. Also tried with iron at 400, 600, and 800 degrees and no luck.
        I have never done it myself, sorry. It's very difficult to do. Some suggest sucking solder off each pin works, then preheating the board.
        • gijoey198079
          • Dec 2012
          • 53
          Yea, that's what I have done before but I can't get the solder hot enough for some reason. I even tried adding some more to get it to come off but no luck. If I figure it out will post back.
          Thanks.
          • ghiotom
            • Oct 2012
            • 41
            My advice is to treat yourself to a Christmas gift and get yourself a Hakko 808 desoldering gun.
            • gijoey198079
              • Dec 2012
              • 53
              Yeah, I wish. The one I have is adjustable temp up to 900 and I have various different solder suckers as well. I just tried again with the heat gun and acutally melted a regulator on the other side of the board before losening the solder, oh well new board is only about $60.
              • DynaxSC
                Extreme High Current & Low Voltage Short Killer ??
                by DynaxSC
                Hi Folks
                I'm looking for a extreme high current short killer solution for a reasonable cost.
                I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                After taking off the socket, the shorts dissappear again.
                The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                10-15-2024, 10:13 AM
              • Stephen
                MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                by Stephen
                I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                02-06-2025, 12:03 PM
              • adelfr2009
                HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                by adelfr2009
                I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                09-28-2025, 10:21 PM
              • Victor Moreira Silva
                Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                by Victor Moreira Silva
                I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                Well, my decice specs are the following:
                Model: Acer Nitro 5 AN517-54-55T5
                CPU: Intel Core i5-11400H
                GPU: NVIDIA GeForce GTX 1650
                Motherboard: GH51G LA-L181P Rev:1c
                The symptom:
                When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                05-26-2025, 10:49 AM
              • Geeker007
                9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                by Geeker007
                Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                I am new to electronics repair, so my queries could be naive but I am ready to learn.
                So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                01-28-2025, 03:31 PM
