KDL-40S2000 runs fine 10min then shutdown and 4 blink
  • ryan74
    • Oct 2012
    • 471
    • usa
    Kdl-40S2000 (Feb2006)
    panel-LTY400WS-L02
    Shutsdown after 5min. with 4 blink code(backlight trouble)
    I read inverter board failures are common
    Backlight connector voltage while tv is on.
    1)18V= 18.04V.
    2)18V= 18.04V.
    3)18V= 18.04V.
    4)18V= 18.04V.
    5)G
    6)G
    7)G
    8)G
    9)Relay_on= 3.537V.
    10)AC_Off_Det= 0V.
    11)pwr_on= 3.320V.
    12)G
    Inverter board #
    CSN303-00
    PCB2676
    A06-12628D
    PCB2677
    A06-12629D
    I think this is a replacement part but i do not want to pay $144 US.
    http://www.shopjimmy.com/sony-1-789-...t-inverter.htm
    If someone knows what usually causes this error on the inverter, or what parts are needed(if available), I would like to repair the board.
    I will post pics tomorrow. to dark now.
    -Edit- I just noticed the standby light is not on in front when it is off.
  • ryan74
    • Oct 2012
    • 471
    • usa
    Re: KDL-40S2000 runs fine 10min then shutdown and 4 blink
    I took the cover off inverter and screwed boards down and now it has not shut off or a blink code for 45 min.. shutdown may occur random but has always been 4 blinks.
    Going to leave it going overnight.
    I went through this but it didn't help. Same model and panel.
    https://www.badcaps.net/forum/showthread.php?t=21443
    I have 3.327V at stby on power supply but no front stby led when off.
    Green power and picture/timer led both work.
    I read it goes into stby after sleep timer so I will try that.
    This is another tv out of a trailer at the dump but it looks good.
      It is a common problem with Sony to have loose lamp connectors on the inverter board. If tightening the screws up doesn't fix it fiddle a bit with the lamp connectors (the new design doesn't use wires but instead metal hooks that go from the inverter into the panel.)
      • gilly1984
        • Jun 2012
        • 751
        I had a very similar sony bravia, check this thread. Tv is still working fine to this day.
        https://www.badcaps.net/forum/showth...highlight=sony
        Do NOT touch heatsinks when testing for voltages as they may be LIVE!
        • tibimakai
          • Jan 2012
          • 3680
          If I remember well I have worked on one of these(or maybe it was 2500?) and I had to replace two ccfl tubes inside the panel. One it was bad and another it was blinking.
          • ryan74
            • Oct 2012
            • 471
            • usa
            Over 12 hrs and still running.
            It seems most likely to be a bad connection then.
            I went into menu and turned up backlight to max and it is still on.
            I will run it this way for a while.
            Good score from dump IF it was just a bad connection.
            The last sony kdl I got from dump just needed firmware update and worked.
            • gilly1984
              • Jun 2012
              • 751
              Fingers crossed for you pal, You beat mine, cost me £20 in the end
              Turn off auto backlight too.
              • ryan74
                • Oct 2012
                • 471
                • usa
                Still no standby led in front. no voltage at the led either
                I dont see auto backlight under menu/picture
                • gilly1984
                  • Jun 2012
                  • 751
                  Mine was a KDL-S40A12, its in the link a couple of posts back.
                  When off it had no led, on it had green led, when in standby it had red led.
                  You could only enter standby by pressing power on the remote, power button on tv turns it completely off.
                  It may be under advanced.
                  • ryan74
                    • Oct 2012
                    • 471
                    • usa
                    when off, mine doesnt have any led
                    on it has green
                    pressed power off remote, no stby led
                    if i set sleep timer the pic/timer comes on
                    the manual says when tv goes to sleep it enters standby.
                    my tv shutoff with sleep timer but stby led never came on.
                    stby comes on only when there is an error blink code. this must be typical of this model
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
                    • janos666
                      Pioneer LX5090 - 2x Red blink after auto-shutdown
                      by janos666
                      I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
                      03-26-2023, 11:20 AM
                    • EazyBone
                      Un50cu7000 2 blink oddity *partially solved
                      by EazyBone
                      I write this to maybe help another with this TV.
                      So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                      The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                      03-18-2024, 10:24 PM
                    • Vebririon
                      panasonic TX-P50V10E 6 blink led problem
                      by Vebririon
                      I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                      Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                      I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                      05-17-2025, 10:16 AM
                    • cruiser_
                      A1466 820-00165 intermittent shutdown
                      by cruiser_
                      hi there,
                      Got this macbook after liquid damage. Nothing major, cleaned and reflowed what was suspect. Now, the laptop turns on and boots up but shuts off intermittently - sometimes after a few minutes, sometimes after a few hours.
                      Can be immediately started from keyboard right after. Plug stays orange during this time. No battery.
                      Gives shutdown cause -128.
                      Seem to work fine in SMC bypass.
                      Same shutdown happens with disconnected TP/KB/KBLED/CAM.
                      Observations:
                      - SMC_RESET_L - when pulled down - plug goes orange/green and...
                      10-11-2022, 12:06 PM
