Re: Factory Resets Listing
Hello evreyone my name is John and I have a trouble with my TV set . Two capacitors blown up C503 and C507 from power supply model PSA218-417-R I want to know their equivalent .Thanks
This is a sticky topic.
For a Hannspree HSG1075 (may work for other models)
To access the factory reset menus-
Using the factory remote:
- Turn TV on
- in quick sucession press input, 0, 2, 3, 6, 3, menu.
- go to initialize in the new menu that opens
- go to recall factory data
- enter
Hope this helps others.
Regards,
HansLeave a comment:
Another SONY:
DISPLAY, 5, VOL DOWN (-), PWR
Reset error code: 8, 0.
http://www.youtube.com/watch?v=8oZnSleucJ0Last edited by budm; 01-09-2014, 11:06 PM.Leave a comment:
Try this:Leave a comment:
does anyone know a pioneer? my model is pdp-6070puLeave a comment:
Can anyone help with how to access the service mode (factory mode) on a Sense 51-42 LCD. It's a cheapo 42 inch tv I'm not sure who makes the chassis I would say it's probably far east, the main board is marked B.TR901C 7355 and seems to be used in a few sets. The digital menu looks familiar, I think I saw similar on a small Kenmark LCD combi. The normal Kenmark methods don't work though.
Can post some pictures if it will help.Leave a comment:
That's a great idea... having reset codes. But.. Is thus the same as a software update which did help me awhile back making a non working tv work like new.Leave a comment:
Hi have a lg 42pw450t , was not coming on ,, changed the ysus board and it came on with a loud buzzing noise, and it was getting hot on the side of the ysus, so thought i,d do a factory reset, after i did that the tv did not come on again ,, accept when i unplug the ysus board , can some tell what causing this and how to fix it
many thanksLeave a comment:
You need a factory remote, or one which can operate the TV.Leave a comment:
This may be a dumb question, but I don't how how else to ask it so...
Is it imperative to have a factory remote to apply a factory reset? or...
Is there a way to accomplish the same thing by opening the set and moving jumpers etc.?
ThanksLeave a comment:
I will ask on this thread as well if anyone knows any other Vestel codes other than Menu 4725, 7935 and 1325?
I have a feeling the options I need to change may not have a solution that can be done via remote control (recent chassis) most options in regular 4725 menu are read only. If there's no menu option I'm going to have to investigate attaching something to the GPIO to see if I can trace and find the info I want; this is a big learning curve but may be worth it.Leave a comment:
I've successfully "emulated" the LG service remote codes using some stuff you can download online, it's not ideal but it will get you in there. Google it and you may find it, they basically upload .wav files which when played through an IR LED (from headphone jack of whatever is playing it) issue that command to the TV. As I said it's not ideal, lots of variables (LED, volume level and so on) some just hook an LED to the headphone jack, others build a simple circuit to drive the LED (more reliable), what I did was use an old working remote control with batteries fitted and attached the wav signal to the base of the transistor that drives the LED (s). It did the job, it's ugly, awkward, but I don't need it much.Leave a comment:
It is my understanding that it is impossible to enter the service menu from the stock remote on any LG TV!
But you really need to provide the model number.Last edited by notallbad; 05-24-2013, 06:25 PM.Leave a comment:
Hisense TV.....
goto menu, sound, balance set to "0" then press 1969
be carefull....Leave a comment:
Guys!!! Is there any one who knows service mode for Changhong LCD TV
I tried this(mute on remote & menu on TVset)but not working..
I tried to adjust the gamma setting since the possible problem of this unit was T-Con.tnx.Leave a comment:
Thanks for Badcaps Members for posting information about Factory Reset code. But I have SAMTRON 56v monitor showing CONTROL LOCKED problem ,Also screen disply small size, I tested voltage , components was ok. can someone help me REset
code or method ? Thanks for help.Leave a comment:
Hey Guys,
http://www.factory-reset.com - I've been collecting these and adding to this database for around 2 years now !
If anyone wants posting privileges then just give me a shout, had to turn them off due to an influx of spam a few months back !
JamesLast edited by 3guk; 04-06-2013, 06:37 AM.Leave a comment:
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by RRice25541So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
the color is all outa wack, like the settings have been corupted,
I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
so
The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
when i bring up the menu and type the pass codes to access either mode the menu disappears... -
by howardc64Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
- TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
- Service Menu shows many Bt/Wifi info missing
- Vizio app shows no WIFIVendor file
- Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
by dxzhowdy yall,
back in this last december i lost my svp for my thinkpad, then i found this technique and it worked successfully.
the only thing i found weird was that now in the bios menu, specifically under the secure boot configuration in the security tab, it went from mentioning microsoft windows 10 to now showing microsoft windows 8 when i scroll over the restore factory keys option.
and im wondering if my current problem is due to the flash/patch ive done:
im having a hard time activating windows 10 pro :lenovo thinkpad e480 that i purchased...-
Channel: BIOS Requests ONLY!
by Retro140Hello,
So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button... - Loading...
