Daewoo LCD 42" model DLP-42C1
  • bohaboha
    • Nov 2012
    • 972
    • sweden
    Re: Daewoo LCD 42" model DLP-42C1
    thank you for the tip
      You need to use volt DC to test, 20V range is fine.
      • bohaboha
        • Nov 2012
        • 972
        • sweden
        i ll do it tomorrow i have to put back everithing so i can test it again i was thinking wat i did on the pics will help but no probleme better to be shure thank you
        • bohaboha
          • Nov 2012
          • 972
          • sweden
          hi here is the test on the regulators
          i try to find out the datasheet here: http://pdf1.alldatasheet.com but it is not that easy
          IC507 =AZ1085S
          25EI
          504BJ
          pin 1 =0.00vdc
          pin 2 =0.00vdc
          pin 3 =0.40vdc
          IC508 =1084_33
          064OBL
          pin 1 =0.00vdc
          pin 2 =0.03vdc (free to air)
          pin 3 =0.40vdc
          IC711 =EH16A
          637J06
          pin 1 =0.00 vdc
          pin 2 =3.29vdc
          pin 3 =5.09vdc
          there is only these 3 regulators on that board
          if you want me to test some other part just tell thank you
          • bohaboha
            • Nov 2012
            • 972
            • sweden
            hello tom,selldoor and all out there
            i did some other test on th main board and the psu:
            on the main board:
            P803A
            Pin 3 =0.32vdc
            nothing on the other
            PA912
            Pin 1=3.29vdc
            Pin 6=3.26vdc
            nothing on the other ones
            PA911
            Pin 1=3.29
            Pin 4=3.29
            for the psu
            it is very strange
            I have removed the psu circuit boards from television and tested with power on
            it is very strange I have power everywhere but very low 71VAC on the hot side and the cold side throughout 12.9VDC all this on the back of the board
            also inCN2, CN3, CN4, CN5, CN6 of all, I have 12.8 or 12.9dcv.Where i just found 1 or 2 pins in differents CN
            When I measured and circuit boards were mounted on the TV I had 114VAC at the bottom is hot side except I had 98VAC IC2 and IC3 around 20Vdc and allmost nothing
            CN3
            Pin 5=4.9vdc
            CN4
            Nothing on all pins
            CN5
            Nothing on all pins
            CN6
            Nothing on all pins
            • bohaboha
              • Nov 2012
              • 972
              • sweden
              #26
              Good evening after a long stop now it is time to go on this tv again
              i did some change on my psu :2 new bridge rectifier BD1 and BD2 + a new IC1
              the old one was blown but keept somehow together wen i desoler it it went in 2
              parts then Q1 and Q5 are changed too and some resistors
              Now after reading a lot here tom66 and many other how to test a psu so i did
              a jumper on CN3 5VS and P/O and did some test :
              CN3
              12V pin 1 i find 7.60DCV
              12V pin 2 i find 7.60DCV
              GNDpin 3
              GNDpin 4
              5VS pin 5 i find 5.12DCV stady
              P/O pin 6 attached to pin 5 =5.12DCV
              GND pin 7
              NC pin 8
              on CN2
              30V pin 1 i find 19.17VDC
              30V pin 2 i find 19:17VDC
              GND pin 3
              GND pin 4
              CN5 and CN6
              B/O Pin 1 i find 0.01 VDC
              Dim Pin 2 0.01 VDC
              GND Pin 3
              GND Pin 4
              GND Pin 5
              GND Pin 6
              GND Pin 7
              24 v Pin 8 i find 15.58DCV
              24 v Pin 9 i find 15.58DCV
              24 v Pin 10 i find 15.58DCV
              24 v Pin 11 i find 15.58DCV
              24 v Pin 12 i find 15.58
              CN4
              Dim Pin 1
              B/O Pin 2
              NC Pin 3
              GND pin 4
              GND Pin 5
              NC Pin 6 i get 7.56DCV
              12V Pin 7 i get 7.56DCV
              the relay is klicking att start by plugg in the power all the other boards are
              not connected during this test so now i wonder if i can reconnect the other
              boards and keep the jump on the CN 3 and test it or wat to do?
              any help will be great thank you
                All the voltages are low.
                Please can you test your meter - measure a fresh 1.5V AA battery - see if it measures nearly 1.5V.
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Hi - I was hoping you would get a better camera for christmas and retake the pictures.
                  • bohaboha
                    • Nov 2012
                    • 972
                    • sweden
                    #29
                    Hi tom,selldoor
                    The dmm is quite ok i did test a new battery and it is ok
                    i think is something on the psu ho is not corect yet maybe the big capacitor that i replaced
                    the old one :180uF450v and the new one have 220uF450v i d´ont know if it can affect
                    or maybe because i use a pc jumper with out a transistor to short the 5vs and P/O pins
                    as you can se on the attached pics
                    selldoor yes i have a camera now lol here some pics
                    thank you
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      Hmm not sure about the photos - perhaps try again in daylight near a window if it ever gets light in Sweden.
                      The flash makes every joint look suspect!
                      If you can get it, one decent well lit picture of the whole board is better to follow.
                      Resistors R14 and R55 dont look soldered back on the left side?
                      Re you measuring VAC are you sure your meter was set on AC
                      not DC and what did you use for ground? On the primary side it is usual to use the negative leg of the Big cap ,not the chassis or ground screw.
                      • bohaboha
                        • Nov 2012
                        • 972
                        • sweden
                        #31
                        Hi you mean the early measuring in the first page yes it was on ac but i did it with Steinel Digi Check3 this meter alternate automaticly from AC to DC depending on wat he find
                        and AC was the resolt
                        but the lasts measuring i did it with DMM BS1901W and all was DCV measuring
                        i´ll try to do better pics as soon as possible
                        thaank you
                        • bohaboha
                          • Nov 2012
                          • 972
                          • sweden
                          #32
                          Hi again selldoor here some pics i hope they are better you did not say anything about the big cap i assume it is ok then or do i have to put back the 180uF 450v
                          thank you
                          • selldoor
                            Slow Learner
                            • 7870
                            #33
                            No I meant this:
                            for the psu
                            it is very strange
                            • bohaboha
                              • Nov 2012
                              • 972
                              • sweden
                              #34
                              yes exactly it was 71VAC on the table and i had 114 when mounted and all the other measuring .is the pics ok this time?
                              i beleave now the situation changed because as i did change the BD1 and BD2 plus Q1 and Q5 and R14,R55 and yes they are soldered but i will resoldered
                              • bohaboha
                                • Nov 2012
                                • 972
                                • sweden
                                #35
                                Good evening
                                please i need your help to go on this project
                                thank you
                                • bohaboha
                                  • Nov 2012
                                  • 972
                                  • sweden
                                  #36
                                  hey Tom and Selldoor and everyone else here,please I need your support.
                                  I have done a few things on this PSU until now.
                                  New on the board= Q1, Q5, BD1 and BD2 plus I changed R14, R54 and R8
                                  and some diodes D21, D23 .
                                  performed some measurements:
                                  from the minus of the C23 :
                                  to IC1 pin 8 i have 10.7DCV
                                  to D21 = C23 to 10.9DCV
                                  to IC2 Pin 12 = 00.0DCV
                                  to D8 = 9.7DCV
                                  Now from the minus of the C32 :
                                  to: 5vS = 5.5VDC
                                  to P / O = 5.5VDC
                                  Pins 12V = 7.4Vdc
                                  to CN5 and CN6 :
                                  from the minus of the C32 to Pins 24V = 15.5Vdc
                                  the C4
                                  from the minus of the C32 to Pins 12V = 7.5VDC
                                  To CN2
                                  from the minus of the C32 to Pins 30V = 19.1Vdc
                                  I still do not have them 12, 24 and 30V needed.
                                  what and where shall i look next?
                                  thanks in advance
                                    So, I am a little lost, bring me up to speed: Do you have any DC output voltages from the PSU yet, aside from the 5V STBY?
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #38
                                      Yes, lost me as well, not that it takes much!!. When we cant see the boardsor what you are doing sundry measurements dont mean a lot, so we have a more boring approach. I looked at this yesterday and thought we are going to have to start over again - the 71vAC threw me completely.
                                      So, with a source connected Tell us again what happens from when you plug in, then switch on to the stable fault state. What doies the power light do, what does the screen do, any noises clicks etc - any sound?
                                      Then when it is plugged in but not switched on what is the voltage on the Big Cap ( CARE HIGH VOLTAGE) then what is the voltage after you have pressed the power button.
                                      I see now the sockets are all labelled so make another list as you did before and measure all the voltages on all the pins (meter on 200vDC black probe on a ground screw)
                                      Do this with everything connected, if you can.
                                      Retest the voltage regulators on the main board and post the results as you did before with the board number, part number and 3 voltages.
                                      • bohaboha
                                        • Nov 2012
                                        • 972
                                        • sweden
                                        #39
                                        Hi sorry i d´int specifie that all the measuring done on post36 was on the board out out of
                                        the tv and with jump on 5VS and P/O. On the C23 the big cap i have 326d ,ok i will put
                                        back everything in place and be back to you soon thank you
                                          There should be around 390V across that cap if the PSU is working, 325~340V or so in standby.
                                            HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 05:27 AM
                                            HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                            This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                            This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          • edugimeno
                                            Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                            by edugimeno
                                            Hi!!
                                            Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                            I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                            At a certain point, moving stuff around, I put all wires back in place and...
                                            03-24-2024, 02:31 PM
