Daewoo LCD 42" model DLP-42C1
  • bohaboha
    • Nov 2012
    • 973
    • sweden
    hey everyone i have this Daewoo that I have found in garbage, I thought it would be easy with a few capacitors to be replaced but i found a blown resistor R14 on the power board I hope you can help me.I have taken some pictures but they were bad so I add here a copy from the internet I have done some measurements but I'm not sure if they are right for my dmm is not of the best quality but I have a "Digi Check 3 from Steiner" that did the trick when it comes to VAC and VDC I have started with power board FEL-42-C2 on which I have marked the different values of the image itself and som images of the tv i have to say that all the DCV are done with power on otherwise nothing att all.We use 220VAC in Stockholm.Any help are realy welcome thank you
  • bohaboha
    • Nov 2012
    • 973
    • sweden
    Re: Daewoo LCD 42" model DLP-42C1
    hi same help please
    • selldoor
      Slow Learner
      • 7870
      No one is going to help you without good pictures of your boards. Distance troubleshooting is too difficult without them.
      • bohaboha
        • Nov 2012
        • 973
        • sweden
        thank you i´ll try to fix a better pics very soon i hope
        • bohaboha
          • Nov 2012
          • 973
          • sweden
          Hi i add here a new pic of the TCON it is the best i can get jut now
          but please Selldoor the pic of the power board is quite clear no?
          thank you
            So... Did you tell us what the problem with the TV actually is?
            Does it show a power LED when plugged in?
            When trying to turn it on does the LED change or disappear?
            Does the backlight illuminate?
            Does an image show?
            Can you get sound?
            • bohaboha
              • Nov 2012
              • 973
              • sweden
              hi Tom there is only power LED when i plugget
              nothing else just black and no sound and i can not power on with start button
              just plugg or unplugg the power also i do not have the remote
              • bohaboha
                • Nov 2012
                • 973
                • sweden
                i forget to specify that the LED is blinking all the time from red to green
                  The LED blinks green/red as soon as plugged in?
                  • bohaboha
                    • Nov 2012
                    • 973
                    • sweden
                    yes
                      I would immediately suspect the main / AV board...
                      • bohaboha
                        • Nov 2012
                        • 973
                        • sweden
                        not the power board? even if it was a broken resistor on it R14
                          No signal is going to the power board to turn it on, the power board may also be faulty but in the very least the main board appears to be too.
                          • bohaboha
                            • Nov 2012
                            • 973
                            • sweden
                            so i have to start with the main first i did some mesure on it only when power is on
                            i ll add a pic so you can se but i am using my iphone for that and the result is very bad anyhow i add here a pic from the net
                              Test the regulators:
                              https://www.badcaps.net/forum/showthread.php?p=274391
                              • bohaboha
                                • Nov 2012
                                • 973
                                • sweden
                                wich ones? i did as you se on all
                                  See the post -- it explains exactly how we like the data presented.
                                  • bohaboha
                                    • Nov 2012
                                    • 973
                                    • sweden
                                    aha ok i´ll do it that way
                                    by the way you remember my Samsung plasma i just took down all the boards to sell on Ebay and i even gott an other plasma samsung even that one broken screen but it is 42" i ll put all on sale on Ebay thank you
                                      Good luck, and it's great to get spares into the market. Remember to label parts correctly, or they will not be found!
                                      • bohaboha
                                        • Nov 2012
                                        • 973
                                        • sweden
                                        hi again first i want to explain that i have an usual Dmm :BST=British Standard Tester
                                        model number BS1901W and when i test with this on ohms he is standing all the time on 1 to the left side of the screen it seems to be normal when i asked the seller here is some pics
                                          HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        • edugimeno
                                          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                          by edugimeno
                                          Hi!!
                                          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                          At a certain point, moving stuff around, I put all wires back in place and...
                                          03-24-2024, 02:31 PM
