Need guidance scoping YSUS board.
    Re: Need guidance scoping YSUS board.
    Almost always it will buzz if that is the case.
    https://www.youtube.com/watch?v=-iAm82lhky4&t=1m10s
    • johnboy1313
      • Nov 2012
      • 1959
      Well, there's no buzz so I guess that's promising.
        You need to check in a dark room, if the panel does not glow, then something is wrong, but otherwise, I expect a dim glow to be visible.
        • johnboy1313
          • Nov 2012
          • 1959
          I checked it in a dark basement after the sun went down. I don't see any glow whatsoever.
            Very odd, it does worry me that there is a panel fault, but I have never heard of an LG with it...
            It could still be a Y-buffer fault. Cannot rule that out at present.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
