Philips 22PFL3505D/F7 no power
    Re: Philips 22PFL3505D/F7 no power
    Originally posted by retiredcaps View Post
    If you have never used a multimeter, see this fellow Canadian 5 minute video
    http://www.youtube.com/watch?v=bF3OyQ3HwfU
    My 2 seconds to black guide also has a section on multimeters and how to measure.
    ok thanks. still need a battery ill have to pick one up tommorow.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
      im not sure on whare i can find your guide.
      My Computer.
        https://www.badcaps.net/forum/showthread.php?t=10419
          thanks.
          My Computer.
            when testing resitors am i suposed to use the 200 setting or the 2000 setting? and does anyone know what readout i should get it just flash's for sec then goes blank.
            My Computer.
              k i think its the 2000 setting i seem to be geting a reading above 500 how do i know if ones bad?
              My Computer.
                Check your fuses first. Use the continuity setting on the meter
                  allready checked the fuse. seemed to be good.
                  My Computer.
                    At this point, I would just use the continuity setting and check the diodes and capacitors for shorts. Check the diodes in both directions
                      wait i think what i was testing were the 4 diodes for the rectifier. what setting do i use to check the caps
                      My Computer.
                        You really cant test caps in circuit. But you can check real quick to see if they are shorted
                          Did you test the diodes using the diode setting? You need to check for opens as well as shorts
                            whats the diode setting? this multimeter has alot of settings sorryits the first time ive used one.
                            edit
                            if you were refering to the setting with the arrow symbol that was what i was useing.
                            My Computer.
                              how do i check if there shorted? i can remove them if i need to.
                              My Computer.
                                The diode setting is at 6 oclock on your meter. It has the arrow symbol with the line on it.
                                http://www.youtube.com/watch?v=hRKzZTk27Ug
                                  yeah got that.
                                  i am getting readings of 506 509 489 498
                                  My Computer.
                                    ok so from what i saw in the video i think there good.
                                    My Computer.
                                      I don't see a continuity setting on your meter, so just check resistance across the pins of the capacitors. They should all read very high or out of range
                                        ok
                                        My Computer.
                                          IN5397 x4 2 measure above 500 2 under.
                                          My Computer.
