Plays fine for 5 to 15 minutes then picture and controls lock up. Cycle power comes back on fine for another 5 to 15 min. Any help on which board may be causing this problem?
Panasonic TH-42PX60U Locks up
Tags: None
Re: Panasonic TH-42PX60U Locks up
Any power LED blinking? Does it lock up on just TV or any source video?
As efan said, check the fans. They get clogged and this sounds like an overheat problem.
Have the back off while testing? Direct a fan at the DG board area to keep cooling.
Check power board voltages when normal and failed.
Sounds like either the H board or (more likely) the DG board (MCU).
T
PS - Sudden problem or was there an "event" that could have caused this? Lightning storm or power surge?veritas odium paritComment
No blinking. Steady on. No event. Just started last week. Some times the picture freezes and sometimes it goes to a multi colored screen. Remote and onboard controls inop. Cycle power and it's back to normal for a while. Will check fans and try other measures. Thanks.Comment
Reseat the LVDS cable... if you need help locating it post some pictures.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I have pulled the DG board. I've located several on line. My question, is the suffix code important or will any of them work as long as they are the right part number?Comment
If you can get one with a matching suffix, go with that. It can sometimes be important, but only Panasonic could confirm whether or not it prevents parts working together.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
What is your original number?
Should be TNPA3903BBS or BBT. Tri-State Module has them for $31 with 6 mos. warranty.
http://www.tristatemodule.com/p-2321...h-42px60u.aspx
Tveritas odium paritComment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by dajokerMy old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
I chased my way through the PSU, and a board, with no results.
Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
I only have the right half of the picture.
Left half is completely blank.
now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
all the other voltage rails...09-24-2024, 04:39 AM - Loading...
