vizio v037l fhdtv20a no picture
  • beer-b-q
    • Nov 2012
    • 38
    • usa
    Re: vizio v037l fhdtv20a no picture
    Not on the main board just on the PSU.
      Are all the fuses on the PSU OK then?
      • beer-b-q
        • Nov 2012
        • 38
        • usa
        Not on the main board.
          Sorry, I'm lost. Are there any fuses on the PSU (apart from the 8mm x 20mm mains ones.)
          • beer-b-q
            • Nov 2012
            • 38
            • usa
            Not that I can find
            • beer-b-q
              • Nov 2012
              • 38
              • usa
              #26
              The big capacitor rated 648 I'm only getting 604 uf.
                Which capacitor is rated 648? That is a very unusual rating.
                • beer-b-q
                  • Nov 2012
                  • 38
                  • usa
                  #28
                  Actually its rated 680. The one on the right under the cover.
                    The problem seems to be in your main board from the reading of the LDO outputs and also bad PS_ON signal by the main board.
                    Can we see the pictures of the whole main board?
                    • beer-b-q
                      • Nov 2012
                      • 38
                      • usa
                      #30
                      The 1st pic I uploaded is the whole board minus 3 caps.
                        As log as there are no LDO regulator to the right of the pciture.
                        • beer-b-q
                          • Nov 2012
                          • 38
                          • usa
                          #32
                          Here's the right side.
                            u21
                            l112
                            g1117
                            1. .6
                            2. 1.240 (The output should be = 1.25 +0.6 = 1.85V)
                            3. 2.514
                            u19
                            l112
                            g1117
                            1. 1.12
                            2. 2.515 (The output should be = 1.25 +1.12 = 2.37V)
                            3. 5.02
                            This is the way to figure out if the adjustable regulator is good or not:
                            Notes: we are looking at the regulator with the Big tab up (the big tab is tied internally to the center pin).
                            Adjustable regulator will have two resistors attached to it, one resistor (Rfb) is between pin1 and pin2, another resistor (Rg) is between pin1 and ground. Pin3 is an input pin.
                            The voltage between the Adjust pin (left pin) and the center pin (Pin2, output) will always be 1.25V +/- 2% (this is the precision voltage reference), if it is not, it is bad.
                            To figure out what the output voltage should be: measure the voltage between pin 1 and ground and add 1.25V to that number, that is the output voltage on pin 2 but you have to make sure you do have 1.25 between pin 1 and 2 as noted above
                              Good catch on U21. I completely missed that.
                              Not sure about U19 though. It would be rare for an LDO to fail with increasing output. But I suppose anything's possible with the cheap LDOs vizio used.
                                I have MAC Cinema Display monitor with 3.3V that puts out 4V, it can be due to leaky pass transistor inside. Anything possible.
                                  I have also had temperature sensitive LDOs. Freeze-spray them and they come right back to life for a few minutes.
                                  • beer-b-q
                                    • Nov 2012
                                    • 38
                                    • usa
                                    #37
                                    I am very new at this and I am trying to understand what is going on. I tested all of the regulators vdc between 1 and 2 pins and I get 1.25 on all but u44 and u16. I soldered a fuse on top of f3 and jumped the 5dcv to pson and the screen is on.
                                      Screen lit up? Or did you get an actual picture?
                                      • beer-b-q
                                        • Nov 2012
                                        • 38
                                        • usa
                                        #39
                                        Just screen. Should I in cable and see what happens?
                                          I think the regulators Budm pointed out need replacing, but it confirms the power supply is working properly.
                                          You will likely not get video (no menus or cable, HDMI, etc.) until the regulators are replaced.
                                          • csmith
                                            Vizio D50u-D1 Powers up no picture
                                            by csmith
                                            I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                            Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                            supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                            issue. Set will power up with remote but not power off....
                                            07-11-2025, 11:52 AM
                                          • gavric
                                            Vizio M70-C3 Half picture is bad, main board on its last leg?
                                            by gavric
                                            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                            When tv powers on vizio V logo shows nice on whole screen. picture 1
                                            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                            When i click video to start playing picture goes black(like when you change...
                                            09-02-2021, 08:55 PM
                                          • ggil44
                                            Vizio M65-E0 No Picture, No Sound
                                            by ggil44
                                            Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                            09-03-2024, 08:30 PM
                                          • maricm
                                            Vizio m65-c1 picture flashing on and off on the screen
                                            by maricm
                                            HI all,
                                            hope someone point to the possible issue before I start buying replacement parts.
                                            Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                            Backlight stays on all the time,
                                            Sound works fine.
                                            screen keeps changing form black to full picture in about 1sec intervals.
                                            Picture looks fine with no visible artifacts.
                                            I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                            Disconnecting left and right ribbons on...
                                            11-25-2023, 06:32 PM
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
