Sanyo DP32746 capacitor help
  • thor2015
    • Nov 2012
    • 10
    I am repairing a Sanyo DP32746 TV. However I am having some difficulty finding replacement capacitors.
    To give a brief synopsis of the problem, the TV will not turn on. There is not even a standby light when it is plugged into a known good outlet. Fuses are good. Power cord is in excellent shape with no shorts or opens detected. All solder joints are in good shape with no hairline fractures. I do not see any indication of burned or lifted traces. The one thing I did notice is one of the 200 volt caps is bulged at the top. The capacitor does NOT have a cover on top, plastic or otherwise. The top is scored with a "+" pattern for the vent and is metal.
    Also, please- I just want to find the replacement caps. There may or may not be another problem existing on the power supply board or even on another board altogether. The bottom line regardless of what the actual problem is is that I do not like caps with bulging metal tops.
    The original capacitors are Nichicon and are on the power supply board. The bulging capacitor is a 200 volt 820 uF GG series with a package dimension of 30mm dia. x 25mm tall. I would like to replace the 2 other capacitors, one being another 200 volt 820 uF and the 3rd being a 200 volt 470 uF with a package dimension of 25mm x 25mm series GN. They are all snap-in style capacitors that are then soldered onto the board.
    I am unable to locate either of the GG or GN series in the values I need. I found similar Nichicon capacitors with the right voltage and capacitance ratings and the same package dimensions but they are a different series. I was able to find the rated ripple on the Nichicon data sheet to make sure I am getting the same or higher but where I am stuck is trying to locate the ESR value on any of the Nichicon data sheets. Any help would be appreciated. Thanks.
    master hoarder
    • May 2008
    • 12175
    Re: Sanyo DP32746 capacitor help
    High voltage caps like these are usually general purpose so that's why you may not find ESR value mentioned in the data sheets. In such cases, just replace the original capacitors by capacitors that meet or exceed the ripple current rating value while keeping the voltage and the capacitance the same.
    • thor2015
      • Nov 2012
      • 10
      Thanks for the reply. I'm one step closer to having this TV fixed. =)
      • DrewPhillips
        Capacitor Diarrhea - Nichicon PL Series
        by DrewPhillips
        Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
        The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
        03-02-2025, 10:18 PM
      • nick3092
        Mid/late 80's Nichicon Yellow Caps
        by nick3092
        I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
        08-28-2022, 03:56 PM
      • gabri2211
        external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
        by gabri2211
        Hi to all 😎
        I'm looking for any useful information to repair this interface (I have attached the image).
        On this board I read E3215-1215A_4D.
        This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
        If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
        in particular...
        11-12-2024, 08:08 PM
      • chth96
        Is there datasheet for nichicon LXJ series?
        by chth96
        I want to calculate capacitor ESR referring to below guide.
        https://forum.digikey.com/t/calculat...-from-tan/2633
        I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
        I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
        Is there anyone who still has old nichicon datasheet which has information of LXJ series?
        11-20-2022, 08:11 AM
      • chth96
        Is there any datasheet for nichicon RT(M) series?
        by chth96
        A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
        https://www.badcaps.net/forum/troubl...e-been-blew-up
        and I finally fixed​ this retro game console by soldering varistor and glass fuse.
        But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
        I have spare console...
        11-28-2023, 03:36 AM
