42" Panasonic TX-P42C2E Plasma blinking fast green
  • livewire1
    • Nov 2012
    • uk
    Re: 42" Panasonic TX-P42C2E Plasma blinking fast green
    hi,
    still going strong.
    i used
    http://flattvparts.co.uk/
    reasonably priced parts. was less than £35 with post.
    or ebay, but prices tend to be higher.
    • albaben
      • Jul 2015
      • albania
      Your friend comrades. and I have a problem with the Panasonic TX-P42C3E. the moment that we entered the voltage, flashing green light and heard relays. shortly sekontash stakohen and tend to enter the job again. The same thing happens constantly and simultaneously flashing green light soon. tensions inverter has correctly. I'm in two minds and I am not convinced that the command which, main board or board power suplly. If anyone can give me a suggestion I would be very grateful. Thanks
      • albaben
        • Jul 2015
        • albania
        Your friend comrades. and I have a problem with the Panasonic TX-P42C3E. the moment that we entered the voltage, flashing green light and heard relays. shortly sekonta open and close again to enter work. The same thing happens constantly and simultaneously flashing green light soon. tensions inverter has correctly. I'm in two minds and I am not convinced that the command which, main board or board power suplly. If anyone can give me a suggestion I would be very grateful. Thanks
        • ItepK
          Panasonic TX-P42G30E green light blinking, no video, no audio
          by ItepK
          Hey everyone!
          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
          This post describes my entire troubleshooting process of this TV.
          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
          I've taken the unit apart, and I've started to check some voltages:
          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
          12-22-2023, 05:06 AM
        • SevenOFF
          Denon AVR-X4000 – Fast red blinking after 2nd relay
          by SevenOFF
          I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
          According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
          Here’s what I’ve done so far:
          • Fully opened and cleaned the unit (a lot of dust inside)
          • Removed and visually inspected the AMP board → nothing visibly damaged or burned
          • Testing is done with
          06-18-2025, 09:54 PM
        • fixxy88
          Panasonic 55DX600u repair help - no display fast green then slow red led flash
          by fixxy88
          Hi everyone. I've been given a dead Pana 55DX600u that I hope to save from landfill. I suspect the tcon board or UC1 on that board.
          Set will flash green led and attempt to start, backlight gives a brief flash then set shuts down and red led flashes slowly. Voltages out of PSU look ok. TCon board gets 12v at fuse when attempting to start and 3.3v on L1 but main IC gets warm very quickly (heatsink/cover removed, felt with back of hand) during the second or two the 12v is applied before PSU shuts down. TVS diodes on lvds input lines are not shorted, no caps appear to be shorted. ...
          02-22-2023, 09:14 PM
        • shahnld
          Sony kdl 65xg9505 green amber blinking
          by shahnld
          Good Day.
          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
          01-03-2024, 03:05 PM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
