Is this 55" Hitachi a good buy? (lines on screen)
  • mattpd
    • Oct 2012
    • 302
    Re: Is this 55" Hitachi a good buy? (lines on screen)
    I found two bad mosfets on each bad ysus board I have. Location q290 and q291. Marked SGP403 manufactured by SK in a TO263 package. Now just waiting 3-4 weeks for parts to arrive.
      You will need a new buffer too?
      • mattpd
        • Oct 2012
        • 302
        TV is fixed. It was the ysus board. So if you have one of these TVs that has every other row lit, or it has no display at all yet still has sound, check your ysus, and make sure to put back EVERY screw. I think I broke one of my ysus from only putting in part of the screws.
          Wow, I am glad you fixed it.
          • mattpd
            • Oct 2012
            • 302
            Me too, thanks for all the help. I didn't realize the importance of putting back all the screws on these ysus boards. I could have fixed this thing a long time ago with the new ysus I ordered. Unfortunately I assumed that putting 2 of the 8 ground screws in was ok for testing. It was not ok, and kept blowing those two fets on the board.
            • tieny
              • Feb 2012
              • 478
              So not putting all the screws can short fets on ysus boards? O.o Is this true for all panels? If that's the case I'll probably start doing the same. Maybe thats why theres so many cases of Ysus blowing =P
                I have never heard of it with other boards.
                However, I have heard of extra buzzing from sustain boards when all screws are not installed...
                • mattpd
                  • Oct 2012
                  • 302
                  I did in fact get loud buzzing, and a few seconds later the fets blew. I tried a second time with all the screws in, and the TV has been working for a day now. It may have been coincidence.
                    Will you keep it or sell it?
                    If you don't mind how much do you have invested in it?
                    • mattpd
                      • Oct 2012
                      • 302
                      If I do sell it, I will part it out because it will be worth twice as much. I have way to much invested, maybe $400. I should easily be able to recoup all of it though, and maybe turn a profit. The ysus board that I ended up using was one I bought broken for $35 on ebay when normal price is $100 or more. I fixed it for $4 in parts, and I fixed one of the buffer ICs for $10. So in total, if I wouldn't have wasted money on extra boards, I would have fixed it for $14.
                      Now I have a logic board I bought from ShopJimmy but never opened, an extra power board that is working, and two broken ysus boards that should be fixable. All of these boards are high priced and in demand on ebay so I shouldn't have a problem selling them.
                      I may keep the TV, and offer a mail in repair service for this TV on ebay. I have extra parts to fix the buffer boards and ysus boards, and the TV to test my work before mailing back. These buffer boards are $150 a piece and ysus are $100, so I bet people would be willing to pay $100-$150 to repair/check all 3.
                      • Dennis H
                        • Dec 2012
                        • 17
                        Wow, This is great thread, glad I found it! I too have a 55HDT52 Hitachi, actually paid that crazy money and bought it new back in late 2005. It had been fine until the picture went black. Mine was the whole screen, could not see anything anywhere, but sound was/is perfect and it would change channels and controls worked etc, just couldn't see any display.
                        Like Matt I do want to fix it and I finally did get around to pulling the 140lb monster off the wall for a looksie. It had been on the same wall since we bought it and it was pretty dusty, in fact i was a little embarrassed to realized I had not taken the time to clean it periodically. Especially after reading Tom's comments about the Hitachi's really needing a second cooling fan for the big boards. My not cleaning it may have contributed to it's failure, but who knows.
                        Anyway, once I pulled the back cover off and cleaned the dust off, I started checking the voltage numbers based on diagram I pulled elsewhere off the net.
                        All the outputs out of the man power board seem to be right on except the CN64 which has the Vs and Va. For those I get no voltage output when I use the gound pins in that plug (5/6) and any of the Vs or Va hots, pins 1/2 and 8/9/10. I expect that i should have gotten the 64 and 83 volts checking that way as that method provided the correct outputs for all the other outputs, CN63, CN68 etc.
                        Now, funny thing is, if I touch the black lead to the upper far left heat sink, I get 56volts on any pin, 1/2/3/4/8/9/10.
                        At first I thought that some components may have been bad there, but once I started thinking about it, it looks like all the out put ground paths are connected, so I am guessing the 56 volts I got from grounding at the heat sink instead of the output plug ground pin was due to an open in the hot side somewhere as opposed to the ground side. Then again if I think about it to much, I might prefer to go have a pint or two!
                        I am sorry for so much talk, but I want to ask if it makes sense to start my looking on that main power board? I don't see any burned IC's or mosfets and the CAP's look ok, although I am not sure I trust them. All but two look normal and the two may be normal, or not...They look flat across the top. These are the two big ones at the top left, 450 volt/390Mf. With the board out of the tv (caps in place on board) I probed them , and the rest i saw in the trail over to the Va and Vs output and they seemed to charge up and then go down to infinity fairly quickly. Now, I know all I did was get a "relative" looksie that may be worthless, but they seemed to behave ok?? There was a smaller cap over by the output plug that did not go to infinity. It stablized at maybe 200 ohms or something. It is C1527 and it looks like it's legs bridge the ground going into the output plug and the hot of the Vs (and I could be very mistaken on that too lol).
                        I have the board out and can post pics if that will help or can also start a new thread to, either way is fine.
                        I'd like to trouble shoot this and get it fixed as I prefer to fix things instead of just throw them out.
                        Thanks for any help
                        Dennis H.
                        • ajshoe
                          ajshoe
                          • Dec 2012
                          • 477
                          • usa
                          #112
                          have a 55 Hds52 hitachi. power supply wont bring up CNPPS voltages (5V, 10.5V, 24v) - have checked both standby voltages and they are good. 2 fuses good, no PS schematics available for these. anybody worked on one of these PS ??? could use some help.
                          • bryoneylar@gmail.com
                            • Dec 2015
                            Needing help with same tv if you are not busy. Did u fix yours?
                            • jeyoung12
                              Samsung QN50Q60t lines on screen
                              by jeyoung12
                              Hi all
                              I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                              My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                              This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                              It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                              So....i don't know what end of the C ribbon to work with...
                              02-26-2024, 10:38 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Chrissygizmo
                              Sony KD-55XG9505 lines on screen problem
                              by Chrissygizmo
                              Hello again everyone,
                              This is my latest mission, to try getting this Sony tv back to normal working order…
                              I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                              02-19-2025, 11:31 AM
                            • reformatt
                              by reformatt
                              07-31-2025, 08:37 PM
                            • ggil44
                              Sony XBR-65X750D Horizontal lines bottom of screen
                              by ggil44
                              Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                              05-30-2023, 07:51 PM
