Is this 55" Hitachi a good buy? (lines on screen)
    Re: Is this 55" Hitachi a good buy? (lines on screen)
    Post an ad saying you're looking for TVs like that which have cracked panels. Or sell it and break even. I would normally sell it to someone who is a TV tech and could buy parts directly from Hitachi, or thinks they might have luck at repairing the PSU.
    • mattpd
      • Oct 2012
      • 302
      Does anyone know the return policy for these online vendors that sell boards? I hate to be the guy that buys boards for testing but I might end up trying when I get some spare cash.
        If you buy from eBay, you usually have a 7-14 day returns policy, but shipping costs both ways aren't included.
        • mattpd
          • Oct 2012
          • 302
          Ok, I brought my trusty meter home. It seems there is no VS voltage coming from the psu. I think it should be 90v. Three of the heat sinks are actually ingraved "5v" "11v" and "90v" and I assume they are for testing. The 5 and 11 test good, nothing on 90. Am I to assume the psu is malifunctioning or could there be a legitimate reason it's not putting out 90v?
            Can you measure the 90V with both sustains unplugged?
            • mattpd
              • Oct 2012
              • 302
              I hooked up only the connections necessary to power on and hear the sound (main and logic). I still get no 90v. Also, there are some voltages that are missing or weird that go to the main board. I will be able to test them in a few hours when I get home and I will tell you what it is.
              I think that a faulty board may be signaling PSU to not output 90v. But this doesn't explain the other missing voltages...
                I'm almost suspecting your power supply is faulty...
                • mattpd
                  • Oct 2012
                  • 302
                  Does anyone know what Vsego, Vsago, Vrs, or Vra stand for or what the value should be? According to the service manual (page 58b if you have it) these are all voltages that return from the panel back to the PSU. In actuality the harness connects the PSU and the logic board.
                    They are used to encourage pixel emission or to erase the display. Generally if they're bad you'll still get a picture it'll just be dim or filled with sparkling pixels. Don't know what those each are for Hitachi plasmas.
                    • mattpd
                      • Oct 2012
                      • 302
                      Hmm, ok. Well according to the service manuals block diagram, these 4 voltages are the only ones that go TO the power board everything else goes AWAY. So if there was something signaling the PSU to not generate Vs and Va, it would be in one of these 4 wires, right? Let me see if I can post the diagram.
                        Vsego and Vsago might enable Vse and Vsa; but the other two... I'd GUESS they are the plasma specific voltages, but wouldn't be sure... it would be really strange for the sustain to turn on the Vs.
                        • mattpd
                          • Oct 2012
                          • 302
                          Both ego and ago are 0v, but I still have a feeling it's the power board that is causing the no picture. I guess I can order another one and see if it gives Vs with the y and x boards unhooked.
                            Is there a VS-ON or PDP-GO pin on the power supply going to the main board(s)?
                            • mattpd
                              • Oct 2012
                              • 302
                              From ps to main board I have standby 3.3 and 5, power off, and ACClock. From main back to ps there is PoWER 1, PoWER 2, and PoWER 3. Then another harness has 5.6, 10, and 12 v. Going from ps to main.
                              I don't see any VS-on or PDP-go
                              I tried to get the connection diagram into an image that is legible but its not working. Here is the manual, diagram is page 58. http://www.givemefile.net/smanuals/p...ile/36647.html
                              Strange. There is a pin on the main board labeled Lcd_go, but its not connected.
                              • mattpd
                                • Oct 2012
                                • 302
                                Today I received a new power board, and it gives the same results. There must be something that is preventing the logic board from sending the ON command to the pboard... Is there anything that would go POP on a logic board? All the voltages are so low that I wouldn't think so.
                                  I remember some NEC plasmas have a lock-out where they won't turn on after a failure, they need to be reset. To reset them you held MENU for 10 seconds whilst trying to power on. Maybe there is a similar procedure for Hitachi.
                                  • mattpd
                                    • Oct 2012
                                    • 302
                                    I'm not sure that is the problem because the tv will come "ON" with sound, just no display. I will look around though. You think the front LED flashing 7 times wile it turns on signifies anything or just normal procedure? Also, is anyone familiar with the "knight rider" LED code hitachi uses? I don't understand the code that is flashing and the service manual doesn't help...
                                      I think N times blink with normal standby LED or power LED is the TV just powering up, I have encountered many TVs that do that. I have no familiarity with Hitachi plasmas, though repairing one is on my wish list...
                                      • mattpd
                                        • Oct 2012
                                        • 302
                                        I am still determined to conquer this beast. I noticed that I do get proper VS and VA voltage when the tv first comes on, but only for 1 second and then it quickly returns to 0. I can unplug either buffer and I get the same result. If I unplug the y or x sus board I never get VS or VA. Does this mean anything to you? I have ordered a ysus and logic board. Hoping one will fix it.
                                        • mattpd
                                          • Oct 2012
                                          • 302
                                          I installed a new Ysus board today (without the buffers) and tested my Vs and Va voltage. Both were present and steady! I then hooked up just the top buffer to see if I could get the top 1/2 of the picture working. Unfortunately it caused my Vs and Va voltage to disappear AGAIN! Unhooking the buffer does not fix it either, so I just toasted this Ysus board it seems...
                                          So I have either bad buffers, or a bad Xsus right? Any tips on deciding which one?
                                          • jeyoung12
                                            Samsung QN50Q60t lines on screen
                                            by jeyoung12
                                            Hi all
                                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                            So....i don't know what end of the C ribbon to work with...
                                            02-26-2024, 10:38 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • Chrissygizmo
                                            JVC LT-50CF890(c) lines on screen, trying tape method
                                            by Chrissygizmo
                                            Hi again all,
                                            I’m busy trying to sort this tv out JVC LT-50CF890 (c) , originally i had nothing on the screen, but after removing the Tcon strips off I got half a picture, now while trying the tape method I have a complete picture but after the boot screen I’m getting lines , I will upload photos & any help would be appreciated ...
                                            10-16-2025, 05:41 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
