Is this 55" Hitachi a good buy? (lines on screen)
    Re: Is this 55" Hitachi a good buy? (lines on screen)
    Think about it another way. Thanks to Hitachi's cost cutting, you got a $3,000 TV (which would cost at least $500 now) for $80 plus parts.
    At the time of this TV, Hitachi Media Enterainment was on its last legs. They were hemorrhaging money in the plasma business. So they were cutting costs wherever they could to compete with Samsung and LG who would make TVs last 2-4 years and somehow customers would still come back for more.
    • mattpd
      • Oct 2012
      • 302
      Sigh... I got the buffer today in the mail and got it installed no problem. Although it did not fix the odd/even lines it did fix that thick line that existed 3/4 down the screen. I was happy that at least it was not a waste of money, but then BANG! Something blew up (on y-sus board I think) and the picture went out completely.
      My theory is that the y-sus was half way dead to begin with (only displaying even lines) and for some reason the other half just blew. This y-sus board looks like it has two indentical circuits, each going to a separate buffer board. I was planning on comparing these two circuits to find the bad component, but now that it is completely blown, I'm SOL. This board is expensive so I would love to fix it. Where would you look first? Going over it with a flashlight now to find what went bang.
        It might be an interlaced driver, and maybe the bad buffer damaged it somehow. You have a large number of FETs and IGBTs on the board; check them individually for short circuits across source and drain. Also, check local Craigslist for a TV like this which is the victim of a flying Wii controller, or being dropped -- great for getting parts.
        • mattpd
          • Oct 2012
          • 302
          Can I check them in circuit?
            That should be fine, you will likely find a block are shorted (sharing a heatsink for example), and then you need to remove them one by one until the short goes. Sometimes more than one goes short.
            • mattpd
              • Oct 2012
              • 302
              I checked every 3 pin component that was labeled "G S D" between S and D and I found no shorts. Could it short between other pins or is there another component that is likely to POP?
                Is there a fuse on the board?
                • mattpd
                  • Oct 2012
                  • 302
                  I'm searching hard for a fuse, it's small if its here. There is no short between ground and vcc, va, or vs.
                    If you plug it in, do you still get good Vsus, or does it collapse below 1V?
                    • mattpd
                      • Oct 2012
                      • 302
                      Could vsus be labeled something else? vs?
                        Yeah, sometimes Vs or Vsa.
                        • mattpd
                          • Oct 2012
                          • 302
                          If I test vs on ysus board I get 3.8v. This voltage comes from the xsus board. Is it malfunctioning?
                            Vs comes from the power supply, unless it is routed through there first. Test it with the Y-sus disconnected.
                            • mattpd
                              • Oct 2012
                              • 302
                              With the power to ysus unhooked vs falls to -0.4mv when I turn the tv on. Power board daisy chains to xsus then from there to ysus. I was sitting directly in front of the xsus when I heard the pop. It didn't sound like xsus but I could be wrong.
                              I don't 100% trust this meter, I just found it in a drawer. I will bring my nice one home again and test again. If this xsus board is bad too I'm going to cry.
                                I would find it hard to believe the X-sus to be bad. It's completely separate from the Y-sus -- it's not even connected to it through the panel. There's no direct connection between the scan and sustain electrodes, just a gap where plasma forms.
                                • mattpd
                                  • Oct 2012
                                  • 302
                                  in this TV Ysus and Xsus are connected directly through a harness. PSU goes to Xsus which goes to Ysus. I'm afraid its bad because with the Ysus unhooked, Vs was non existent on Xsus.
                                    I remember one Pioneer/NEC I had shut down with no Ysus making identification of shorts difficult. In fact once I plugged it in it flashed red/green continuously until I reset it.
                                    • mattpd
                                      • Oct 2012
                                      • 302
                                      But the TV runs with sound, but no VS.
                                        I dunno then, any Vs with Xsus and Ysus disconnected?
                                        • mattpd
                                          • Oct 2012
                                          • 302
                                          Vs is only labeled on xsus and ysus. Shouldn't vs be coming directly from the psu somewhere?
                                          Hold on, I see the test point on the psu. Let me check...
                                          • jeyoung12
                                            Samsung QN50Q60t lines on screen
                                            by jeyoung12
                                            Hi all
                                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                            So....i don't know what end of the C ribbon to work with...
                                            02-26-2024, 10:38 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • Chrissygizmo
                                            JVC LT-50CF890(c) lines on screen, trying tape method
                                            by Chrissygizmo
                                            Hi again all,
                                            I’m busy trying to sort this tv out JVC LT-50CF890 (c) , originally i had nothing on the screen, but after removing the Tcon strips off I got half a picture, now while trying the tape method I have a complete picture but after the boot screen I’m getting lines , I will upload photos & any help would be appreciated ...
                                            10-16-2025, 05:41 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
