Is this 55" Hitachi a good buy? (lines on screen)
    Re: Is this 55" Hitachi a good buy? (lines on screen)
    Oh, I see it! That IC has a hole in it... wow. Usually they just go on their own accord. If something was real bad, the TV wouldn't power up at all, or all the ICs would be dead.
    • mattpd
      • Oct 2012
      • 302
      I was surprised to see it too. It makes diagnosing things a whole lot easier. I have opted to try to change out the IC instead of the board. I got the old one off with minimal problems, now I'm just waiting on the new one in the mail...
      I'm going to be as careful as possible and triple check my work before plugging the TV, but what if I screw up my soldering job? Is it possible it could damage other boards or even the panel when I turn it on?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        How did you manage to remove that epoxy? Or was it something softer.
        A working TV? How boring!
        • mattpd
          • Oct 2012
          • 302
          Soft silicone I think, i just used a razor. But when encounter epoxy usually 200c from the heat gun and a razor blade will do it. What is this soft glue for? keeping the legs from lifting?
            If you short lines together, you'll likely damage your new buffer IC, but that should be where the damage stops.
            The panel is essentially glass and wires. It's very difficult to break it electrically.
            It just peels off. It's HV insulating epoxy. Because each of those rows are energised with -200V/+400V relative to common depending on the current state of the sustain waveform. I had one buffer with a rather toasty insect (a small fly) between some of the pins. It didn't end well for the insect -OR- the buffer but luckily the part was cheap.
            • mattpd
              • Oct 2012
              • 302
              I wasn't planning on replacing the glue, but I am thinking twice now... Is there anything I could buy locally at a home improvement store? Will these ICs get too warm for hot glue?
                Hot glue isn't great but it should be an acceptable substitute.
                • mattpd
                  • Oct 2012
                  • 302
                  Ok, and what about the "big cap" you talked about in earlier posts? Is it on the power board? They all physically look good, but I haven't put my meter on them yet.
                    If they haven't bulged on this set they're OK. I think the failure on this is simply a random event.
                    • mattpd
                      • Oct 2012
                      • 302
                      I think these ICs are just kind of crappy. There are lots of people on ebay offering repair service for this board for $80-$100 so, I guess the problem is wide spread.
                      Surprisingly this beast has no fans although I think it has room for some. If I get it working I think I might add some. Is there 12v anywhere on the psu I could tap into?
                        More than likely 12V for audio or main board you could run a fan off. Most Panasonics use fans for reliability. Disappointing that Hitachi wouldn't use some, especially if it's an older plasma (much higher power consumption)
                        • mattpd
                          • Oct 2012
                          • 302
                          490 watt max, 393 average. I guess it could be worse for a 2007 55" plasma.
                            Well, for comparison, a 2006 NEC 50 incher (that I fixed) drew close to 550W full white and about half that average.
                            • mattpd
                              • Oct 2012
                              • 302
                              I just ran the tv with the bottom buffer board out and the bottom half of the TV was black as expected but the top half still had the even odd problem. Is this to be expected or do I have more problems?
                                I had the same issue with a Panasonic plasma. Something didn't sync up right when the bottom was out, and I only got an interlaced picture on the top half.
                                • mattpd
                                  • Oct 2012
                                  • 302
                                  Great, thank you.
                                    Oh, I forgot to mention the 550W NEC had two fans. One for the combined Y-sus/Z-sus (all in one board with massive hybrid module), and one for the PSU.
                                    So I think Hitachi were just cutting costs by not including a fan, and it might have lead to buffer failure. You can also install heatsinks on the buffer ICs, Panasonic does this a lot.
                                    • mattpd
                                      • Oct 2012
                                      • 302
                                      What would I use to attach the heat sinks? The epoxy would make it hard to get good contact with the chip.
                                        Thermal adhesive. (Adhesive which is a good thermal conductor.)
                                        • mattpd
                                          • Oct 2012
                                          • 302
                                          15 heat sinks and thermal plaster for less than $5. Thank you ebay. Just think of how cheap hitachi could get them. Weird they didn't include them in a $3,000 TV.
                                          • jeyoung12
                                            Samsung QN50Q60t lines on screen
                                            by jeyoung12
                                            Hi all
                                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                            So....i don't know what end of the C ribbon to work with...
                                            02-26-2024, 10:38 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • ggil44
                                            Sony XBR-65X750D Horizontal lines bottom of screen
                                            by ggil44
                                            Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                            05-30-2023, 07:51 PM
