Can anyone provide a technical guide for a Panasonic TC-P42S30 Plasma?
  • mattpd
    • Oct 2012
    • 302
    I am in search of the technical guide for a TC-P42S30 plasma, GPF14DU chassis. I already have the service manual, but I think the technical guide would be more useful for me. The closest I can get is :
    but the board layout is quite different in the TV I have. Can anyone help a noob?
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Can anyone provide a technical guide for a Panasonic TC-P42S30 Plasma?
    • mattpd
      • Oct 2012
      • 302
      Thanks, but I already have the service manual. Does a technical training guide exist for this chassis?
        Generally the exact training guide doesn't matter so much -- the diagnosis is the same for most Panasonic plasmas:
        http://www.tgohome.com/ServiceManual...nd_extra_info_[TM].pdf
        http://www.tgohome.com/ServiceManual...raining_GPH5D_[TM].pdf
        I can look up the chassis of your particular model to get the exact training manual but those should be a good start.
        • mattpd
          • Oct 2012
          • 302
          I get 404-page not found.
          Never mind, figured it out.
            Try these -- the links got messed up by the forum software:
            • cloo
              Panasonic ZT60 plasma tv with strange behavior and 8 blink code
              by cloo
              I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
              It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
              So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
              After doing a factory reset this problem was gone and the picture was back to...
              01-06-2025, 06:02 AM
            • Alicat
              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
              by Alicat
              Stopped by this site trying to fix my parents Panasonic Plasma TV.
              Model number is TH-50PZ85U
              Power comes on and the red power light stays on solid.
              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
              I also hear a few clicks.
              I also think my parents said there was a thunderstorm and the TV failed after that.
              Section 6 in the service manual talks about power and no screen,...
              10-30-2024, 10:09 AM
            • Lintesir
              Panasonic P42S30 Plasma - Pink sparkles
              by Lintesir
              My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
              There is about a 5cm high region at the top without any sparkles,...
              07-26-2024, 03:16 AM
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
            • badcappo
              Dead Panasonic Viera TX-P65STW50 Plasma TV
              by badcappo
              Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
              Diode type G972s6 - D101 with a short
              Mosfet 06N90E - Q301 shorted
              Fuse T5AH 250V - F103 blown
              Diode D301 shorted
              Relay DG1U-17VDC II - RL001 blown
              I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
              11-24-2024, 11:27 AM
