55" Samsung No Display
    replied
    Re: 55" Samsung No Display
    Originally posted by Loozer View Post
    $45... Not bad
    X-main was only £15 and £18 last two times I replaced one (both on a Samsung plasma!) Did you get it from ebay?
  • Loozer
    replied
    $45... Not bad
    replied
    I hope so too. How much did it cost?
  • Loozer
    replied
    Finally ordered the new board today. Im praying this is the problem.
  • Loozer
    replied
    Wow thanks man. Your wise beyond your years. Ill let you know how it goes (fingers crossed)
    replied
    Alright thanks. Now just curious why that side and not the other?
    It might not look like it from the outset but the boards are entirely different parts.
    The Y assembly (including the Y-buffer boards and Y-main) on the left is responsible for the Scan electrodes -- essentially it addresses each line in the plasma panel one after another to "write" data to it through the bottom buffers. Then, it works with the X-main to make this stored image appear. It's also responsible for clearing the image so it doesn't get stuck on subsequent frames. (Failures are common with this part.) Bad Y-main = 90% of cases, no picture at all.
    The X-main is a single board (no buffers usually) and it is responsible for providing the alternate sustain voltage on the Sustain electrodes. It's also responsible for making the picture light up fully, though you usually see some picture with a bad X-main, it's just very dim or fuzzy. Bad X-main = 50% of cases, you still get a dodgy picture.
    Got this tv free and would be a nice save.
    Ah, the well sought after "free" dumpster/out-on-the-curb TV. I've only had one and it was a nice tricky fix. Water damaged LCD, had to take it to bits and clean the light diffusers, but he gave me the remote and power cord too. Later gave it away at a very low price to a friend who needed one (upgrade from 19" LCD.) Then again, I also picked up a 42" LCD at the tip for £20, and it got me into the hobby, as it was a simple bad cap repair, and I realised how disposable people consider TVs.
  • Loozer
    replied
    Alright thanks. Now just curious why that side and not the other? For future reference. Ill order a new one and pray. Got this tv free and would be a nice save. Thanks again. Your a life saver
    replied
    Yep, that's the X-main. (BTW -- Z-sustain is LG terminology, it's X-main on a Samsung.)
    There's some fuses on it, near the connector going to the PSU.
  • Loozer
    replied
    Mine doesn't get any image at all but ill look into that. Now just to make sure were talking about the same board I took some pictures. This is the correct one right? Also a pic of everything for reference.
  • Loozer
    replied
    replied
    I have had a vaguely similar problem with a Samsung plasma -- it turned out to be the X-main:
    https://www.youtube.com/watch?v=Bmu12mCOKcU
    I didn't mention it in the video, but I too had some faded bars and dim light across the panel when viewed in a dark room. And the no signal appeared only after about five minutes. Only certain parts of the display registered any light output.
    Luckily, the X-main (same as Z-sustain) was very cheap -- I believe less than £15. I got the TV for £50, so I was quite pleased that it was that simple (and later, it sold for £225.)
    The X-main is the rightmost large board looking from the rear, connected to the panel via ribbons.
  • Loozer
    replied
    None were actually "popped" but bulged upwards. And one leaked on the backside a lil. I cleaned the black residue thoroughly before I soldered the new one in. Its just wierd because now the screen does turn on but just no display whatsoever but that awful gray static . Do you know any ways to trace the problem? I won't get to try anything till late tonight but im all ears. Please help! Thx
    replied
    Did the bulging caps have a plastic cover that was pressed outwards? Or could you see an actual vent?
  • Loozer
    replied
    No I've done all that. Even unclipped all ribbons on t-con and carefully placed back and clipped down. As well as all the plugs. At this point I'm thinkin it has to be a faulty board and I'm okay ordering a new one its just im not sure which board is the problem. There were bulging caps for sure but on the power supply board. Would anything ive done caused this new problem or would these issues stem from tcon board and/or cables? I just want to be certain so I don't buy something I don't even need. Thank you again for the help sir
    replied
    OK, those are good caps. Just worried you might have put poor quality ones in, it happens.
    Since you get startup sound I suspect main board is OK, though it could be at fault it is less likely. Can you please re-seat all connectors on the main board especially the flexible cable going to the T-con PCB (for the plasma panel; if you need help locating it, post back.)
  • Loozer
    replied
    Alright the two 500 v are - manufact (cornell dubilier) series- SLP..... The other is nichicon, series- GN. Hope that helps
    replied
    Sorry, manufacturer of capacitor. E.g. Panasonic is "(M)", CapXon is "CapXon", etc. Post a picture of the cap if unsure showing the label clearly.
  • Loozer
    replied
    Manufacturer as in Samsung? Series I have no clue but I did snap this picture before I left for work. I hope it helps. model is hp-s5053. If not on there where would I find out? Thsnks again.
    replied
    Manufacturer and series?
    There is no need to increase the voltage. (The Internet is wrong on this point.)
    I don't know how you got a 500V capacitor. It's a very rare value. Most stop at 450V. That's the highest voltage needed.
  • Loozer
    replied
    2 called for 270 uf 450 V and one 820 uf 250 V. I was told it was ok to increase the volts so they wouldnt blow again so the replacements were 2- 270 uf 500 V, and 820 uf 250 V. Im kind of a noob still so bare with me. Thanks!
