Sanyo Turns off when sound turned up
  • precario
    • Sep 2013
    Re: Sanyo Turns off when sound turned up
    I have a sanyo DP47460 when I turn on the led go green nothing else after several try the led no came on at all after disconnecting the tv for 10 minutes the same happens, only the 5v standby is on, I need help
    • johnboy1313
      • Nov 2012
      • 1959
      Start a new thread with pictures of the inside of the tv.
      • Poppydom
        • Nov 2013
        Been having the same problem with my Sanyo for several years- originally would shut off only occasionally and just unplugged power and system reset.
        then it popped once loudly when it shut off and then would work but not play DVDs or download online movies- would do the same shut down procedure again and would start up but then it got worse until it wouldn't stay on at all no matter how low the volume was..
        Figured out a workaround since I wasn't impressed with the TV speakers anyway and based on what you guys said it had to be something related to the soundboard circuit, so for a bit of $ and a great sound I bought a good sound bar and just hooked up the audio output so all the sound goes to the sound bar and TV sound is zero and has been working like a charm since Dec 2013.
        as soon as I turn TV sound up will shut off but as long as TV sound is off have had no issues and really enjoying the quality of sound from the sound bar and don't have to use my $ to pay for a circuit board repair or a new one that might give me the recurring problem. Let me know if anyone else has done this with the same good results.
        • Nick24ba
          • Apr 2014
          • Usa
          Worked great for me! I bought a dp47460 47" Sanyo HDTV from a guy on Craigslist for 40$. He said it didn't turn on sometimes and it turned off on him all the time. I thought it was a great deal even if I had to replace p/s or something like that so I bought it. I then brought it home, plugged it up, and it worked! I then started messing around with it and after I hooked up my xbox 360 with hdmi it turned off. So now I've hooked up a speaker dock I had for my iPhone and it's working great! Hasn't turned off yet! I have tv volume at 0. Everything I used to turn up volume to 38 it would turn off and take atleast an hour to turn back on. Now everything works great and my tv sounds better! Anybody who wants to fix their tv by doing this make sure your alternate audio source has it own volume up and down function. IT has to be a unit that plugs into the wall. I then ran the red/white audio outputs from the tv to the speaker dock via a 3.5 to red/white cable.
          • SlickClick
            • May 2011
            • 91
            This should be a good start...
            http://www.youtube.com/watch?v=KSYCn93pz6kgg
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • hugocarmo
              Sanyo VHR-D4710G VCR no sound.
              by hugocarmo
              Hi again guys.
              Today I have a problem with this Sanyo VCR.
              I bought it online, It worked sometimes.
              I recap the Power supply and it started working fine.
              Image is perfect and all digital effects too.
              All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
              I have no sound on playback, on tuner, or aux in.
              On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
              On one of the sound processing...
              01-23-2024, 12:58 PM
            • Zilicon
              AHL50/ ABL52 LA-C701P Rev:1.0 Turns on but turned off after few seconds
              by Zilicon
              Hearty greetings to everyone, trust you all are doing excellently well.
              Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
              The power stables in very rare case. Once it was stabled, everything works fine.
              Once the power switched is pressed, 5V and 3V were present.
              The things i have done:
              1. I have check for shorts on the board, but nothing. The board is short free
              2. Not a power switch problem, it behaves the same without the switch ...
              06-10-2024, 05:05 AM
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:30 PM
