Vizio VW26L-No power
  • Maddart
    • Oct 2012
    • 4
    I got a Vizio VW26L from my brother and the original problem was a Gray/White screen no image no sound. Pressing the power button on/off several times got the thing to function. It finally gave out a couple weeks later, No signs of power when plugged in. I pulled the PS board and found a couple of bad caps. Because i repair old stereos i have most of the caps on hand. Im going to replace the 3 2200uf/10v, 2-1000uf/25v, 3 1000uf/35v and the 100uf/50v caps on the board. I have included a couple of photos. Should i be looking at something else as well-Didn't see any fuses.
    If anyone has schematics or voltages and test points it would be helpful.
    Re: Vizio VW26L-No power
    Well, make sure the caps are low ESR type 105c rating not general purpose caps, since they may or may not work properly in switching power supply circuits.
    http://s807.photobucket.com/albums/y...26L%20HDTV10F/
    I use PANASONIC FM or FR or FC series from Digikey.
    • Maddart
      • Oct 2012
      • 4
      Recapped the PS. Now works as expected. Cheap, easy fix
      • darren19822000
        • Apr 2014
        i have this same issue except i have no clue as to repairing it
        • mmartell
          • Oct 2013
          • 3189
          1. Remove bad capacitors.
          2. Install good capacitors.
          Done.
