LG 50PZ550 / Zenith Z50PV220 clicking not power on, troubleshot but not sure
  • dbdbdbdbdb
    • Oct 2012
    • 6
    • US
    I opened the back, and if I unplug the Zsus board( EAX63551301), then the TV could power on and I can see some pixels moving on screen(from the pattern I can tell it's the "no signal" moving sign). And I tested the output of power board seems OK.
    But if I plug in the ZSUS board, it just keeps clicking 2 or 3 times then goes to standby. There are no obvious swelled caps on all boards, especially the ZSUS board.
    Can I just say that board is broken? Is there some advise to trouble shooting some bad components on that board or I just replace the whole ZSUS board? Thank you very much!
    Re: LG 50PZ550 / Zenith Z50PV220 clicking not power on, troubleshot but not sure
    You can replace the Z-Sus or you can post a picture of it and we may be able to help you repair it.
    • dbdbdbdbdb
      • Oct 2012
      • 6
      • US
      It's the same board, but not from my TV. thanks!
        OK, with the board removed from the TV, test across here for ohms. You should see an open circuit if there is no short on the board.
        • dbdbdbdbdb
          • Oct 2012
          • 6
          • US
          thanks, I will try when I got home.
          BTW, there was a "pop" noise when screen went off on the last day I watched it, then I thought something exploded inside. But nothing looks bad after I checked... weird...
            Yeah, that definitely sounds like a Z-sustain failure. It is very common to hear a pop when these boards go bad. Usually, nothing is obviously failed.
            • dbdbdbdbdb
              • Oct 2012
              • 6
              • US
              you are so right, I tested the cap you told me, and it is SHORT...
              But I think the 4 caps are in parallel also there might be other components shorted causing the test short...? Is there some way to identify? Thanks again!
              BTW, I have a college classmate is pursing his EE Phd at University of Leeds, maybe focusing on electromagnetic fields research stuff...I even think you may know him,hahahah
                It's actually just a general test of the board, a convenient point to see if there is a short. In this case, there definitely is.
                Post a picture of the underside of the board so I can highlight some MOSFETs and IGBTs to test - the devices on the large heatsinks.
                Heh interesting - we do have a microwave, photonics and lasers department here. Terahertz technology is something they are pushing - sub-light lasers for medical use apparently. It's pretty cool stuff and it's supposed to be #1 in the country.
                • dbdbdbdbdb
                  • Oct 2012
                  • 6
                  • US
                  hi this is the new file, I took off those cooling pads to unveil components, I hope it will help. thank you very much!
                    OK, please test each device which has similar pin connections to the one I have highlighted:
                    Mentally number pins 1 to 3 (order doesn't matter but be consistent.)
                    With the board unplugged, set your meter to 200 ohms, and meter across: 1-2, 2-3 and 1-3.
                    Report your readings for each device.
                    For now two-terminal devices do not need to be tested, only three terminal ones.
                    • dbdbdbdbdb
                      • Oct 2012
                      • 6
                      • US
                      thanks a lot. I tested some of them and found it's like vcc and ground are short. So there are many possibilities for different components failing. I just found a cheap zsus board on ebay $17 so I bought it to make it faster. Thank you again, I hope by replacing the zsus board my TV could come back
                        I often do that, I have found Z-sustain (or X-main) for as little as £12, I just replace the board, not worth putting in a £10 Farnell parts order when there could be more wrong. Hopefully it fixes your TV.
                        • AngusY1
                          Hi. I have almost the same problem with my Zenith z50pv220 tv. when I want to turn it on, just clinking and it goes bact to standby. No picture and sound it does not turn on. I bought a new z sustain and a new power supply but the problem is stayed. Somebody has any idea what can I do? Thank you
                          • Sisko
                            Onkyo-593 No power and now clicking sound
                            by Sisko
                            Hi all!!
                            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                            10-03-2025, 02:18 PM
                          • B0r1s
                            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                            by B0r1s
                            PSU - BN44-00878A
                            Symptoms:
                            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                            A weak clicking sound was coming from the transformer.
                            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                            Progress:
                            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                            01-17-2023, 04:58 PM
                          • slimmy182
                            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                            by slimmy182
                            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                            Looking on google I found this:...
                            01-14-2023, 11:55 AM
                          • beetle1303
                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                            by beetle1303
                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                            01-13-2025, 08:49 PM
                          • cmonkey
                            Zenith Z50PJ240 - White Screen with 'Power Only' displayed
                            by cmonkey
                            Turned on my lovely plasma and after about 30 seconds the screen below showed up. None of the inputs are responsive, just the red light flashes when I push it. Remote doesn't work either. To turn it off I need to unplug it and when I plug it in again it turns back on to this screen.
                            I only found one reference to this issue with a different model but it didn't look super reliable. Only mentioned a 'main board fault'. The main board for this one is on ebay for $34 so might need to go with that.
                            Anyone seen this before?
                            Thinking about it some more, it happened...
                            05-19-2023, 01:01 PM
