Stumped by Sony board connectors
  • JVRaines
    • Oct 2012
    I decided to have an adventure and replace some bad caps in a Sony Hi8 VCR. But first I have to disconnect the PSU board to remove it. I'm having trouble with a couple of obstinate wire-to-board connectors. I've wiggled, rocked, pried and pulled to no avail—in fact one of them is starting to rip off the circuit board! Anyone have tips on getting these darn things apart?
    Here is an example (from another spot in the VCR):
  • gilly1984
    • Jun 2012
    • 751
    Re: Stumped by Sony board connectors
    they are fixed to the board. the plastic just keeps the wire together.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • crtfool
      • Jun 2010
      • 82
      As gilly said - they are soldered to the board - now you need to see if you broke the traces when you tried to remove them. If you must remove them, you have to unsolder them.
      • JVRaines
        • Oct 2012
        I understand what you're saying, and that I may have damaged traces. But I'm puzzled about what to do if these connectors can't be disconnected. They appear to be two parts, one locked into the other. And there is at least one place in the unit where the service manual says to disconnect this type of connector.
        Here is a wider shot. The metal cage at the bottom is the PSU. It's supposed to lift out of the opposite side of the chassis. The PSU board is inside and only accessible after the cage is removed. But the cage is held captive by the two visible wire assemblies: one goes to the circuit board at top, and the other goes somewhere far away in the VCR. One end or the other has to be removable, right?
        • lti
          • May 2011
          • 2552
          It looks like the power supply end is removable.
          • JVRaines
            • Oct 2012
            That was my assumption. But others are saying these connectors (which are the same as the one in the first picture, only wider) are not removable.
              I can see the male pins sticking through the gripper, never seen one like that is solder directly to the board with male pin exposed like that.
              • gilly1984
                • Jun 2012
                • 751
                I have come across them before when working on a technics mini seperates, the amp section. From the psu to the main board, had to take it all out together to work on it, was a pain. Didn't fancy de soldering it.
                Last edited by gilly1984; 10-19-2012, 06:16 AM. Reason: stupid phone auto correct.
                  I came across them also that you have to unsolder them from the board,but never see one with male pins sticking out like that.
                  • JVRaines
                    • Oct 2012
                    Thanks for the input, everyone! Today I got a little more determined and was able to finally disconnect them; it took forever pulling straight up. Fortunately the one I mangled only broke its solder joints and didn't mess up the pads.
                    Of course, there are no visible signs of bad caps. But I'm pretty sure this is the board that gave off a hot glycol odor when the unit was turned on.
                    • gilly1984
                      • Jun 2012
                      • 751
                      Ah, so it does. Missed them pins. The technics didnt have them.
                        master hoarder
                        • May 2008
                        • 12175
                        I usually use a small flat head screwdriver (or two) to pry the narrow sides of the connector. After this, the connector comes out much easier.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • m1ch43lzm
                          by m1ch43lzm
                          05-12-2025, 08:37 PM
                        • jb_Bak
                          by jb_Bak
                          CN6401
                          Pin 01 NC
                          Pin 02 NC
                          Pin 03 "BL_ON": 0V
                          Pin 04 "N/C"
                          Pin 05 "STBY 3.3V": 3.5V
                          Pin 06 "GND": N/C
                          Pin 07 "AC_OFF"...
                          09-27-2021, 04:52 PM
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • delpiero3
                          Sony Vaio SVS MBX-261 board failure
                          by delpiero3
                          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
                          Nevertheless, let's say, i don't come as a total beginner.
                          I have this old laptop, which suit perfectly my needs, with the...
                          10-29-2024, 06:16 AM
