Sony Bravia 40" LCD Model KDL40s4100
  • jimb0b
    • Oct 2012
    • 17
    Picked up a non-working Sony Bravia 40" LCD Model KDL40S4100 today FOC. Cleaned it up, checked for physical damage, and then powered it up: power light came on, snow on screen for a couple of seconds followed by blank screen and standby light flashing twice. I haven't opened it up yet but wondering if anyone has any ideas on the best way to short circuit (!!!) the fault finding process. Thanks in advance. This is my first LCD TV although I have done a few computer monitors in the past. And this is my first post here so take pity on me
    Re: Sony Bravia 40" LCD Model KDL40s4100
    Service manual:
    The bad part for this model: from page 11 of the service manual
    IMPORTANT:
    The units in this manual DO NOT contain a self-diagnostic function. If an error occurs, the TV will not stay on. It is our
    is required for this set, the technician should bring both the A Board and the G Board to the customer location.
    • jimb0b
      • Oct 2012
      • 17
      IMPORTANT:
      Yes, I saw that unfortunately. When I first searched, I came across references to the self-diagnostic function of similar models (Sony, 40", LCD with CCFL) which suggested that two flashes of the Standby LED was a inverter board problem. So I thought, great - that will be an easy replacement!
      Oh well, I guess I'll know more when I open her up I've never worked on anything that needs this much bench space before.
        I believe me/Sienoki have this same model with bust screen, but all parts working.
        • jimb0b
          • Oct 2012
          • 17
          Are you referring to Sienoki who posts on this site?
            Yes. I can't remember if it's "S" or "W" we've got, but the boards may be good for either.
            • jimb0b
              • Oct 2012
              • 17
              So finally got some time to take the back off and start looking around. No obvious capacitor issues or burned out components or previous repair attempts. I'm going to do some voltage and continuity checks shortly and check the inverter board. In the meanwhile, here are a few "interior" shots.
              • Village Electronics
                OldPro
                • 118
                My guess is that you have a bad ccfl. That is inside the LCD panel itself. They can be changed but it is not easy.
                  I would remove the balancer board and look real close at the sockets where the board is attached to the lamps, see if the black sockets have any sign of over heat or blister, look and clean the fingers of the board also, insert the board back in and see if the lamp will stay on.
                  • jimb0b
                    • Oct 2012
                    • 17
                    I checked the voltages on the test points behind the transformers and they ranged from 0.1V to 0.4V except one which was 9.1V (see picture). So I figure I have the problem. The next question: is it the transformer or the ccfl? Any ideas on how to figure that out?
                    • jimb0b
                      • Oct 2012
                      • 17
                      Success! I removed the transformer which showed the abnormal voltage, soldered in a jumper and up she came! Using OTA signal, it picked up 12 high def stations immediately. Now all I need to do is find a remote for it.
                      BTW, the efffect of removing that ccfl is practically nil. With any picture on the screen, you absolutely cannot see the difference. When there is a blank screen, it can be noticed from acute angles and then only if it is mentioned.
                      Here are pics of the final result (Craig Ferguson interviewing Susan Sarandon tonight) and a picture of the repair.
                      Tks everyone for your help and advice.
                        Great job locating the cause of the problem. By the way, what resistance reading on the transformer you removed compared to the other transformer? It looks like the transformers are hooked up in series with each other.
                        Other person on the forum had the bad connection problem with the PCB sockets so you may also want to keep an eye on that. I will take some resistance reading of spare SONY balancer board's transformers.
                          Norcal715 with similar problem on a Samsung: http://www.youtube.com/watch?v=oE6K4xBVweA&feature=plcp
                          I think he diagnosed it as a failed CCFL, not transformer.
                          • jimb0b
                            • Oct 2012
                            • 17
                            Thanks!
                            As I had no way to decide whether it was the transformer or the tube, I decided to pull the transformer to see if a) it would work at all and b) everything else is working. So far, everything else seems fine although I don't have a remote for it so it is a PITA to change settings etc. So that is the next job: find a remote Sony RM-YD025 or compatible model.
                            • jimb0b
                              • Oct 2012
                              • 17
                              Originally posted by tom66
                              It was this video which helped me find the problem. I added a "like" and a comment.
                                Ah, so the lamp is bad, not the transformer. Thanks for the link to the YouTube, learning something every day, 1200 hours and the lamp already failed, sad.
                                • jimb0b
                                  • Oct 2012
                                  • 17
                                  I don't for sure whether it was the ccfl or the transformer. Removing the transformer covered both possibilities.
                                  Is it possible to remove and replace a ccfl?
                                  • RenoRJ
                                    • Feb 2014
                                    I had the same problem with my Sony KDL-40S4100. Go green then a couple seconds later Standby light would blink twice.
                                    I unplugged the main connector on the inverter board and left the smaller connector on the bottom connected. The tv came up and stayed on no pic just sound.
                                    I pulled the inverter board off very carefully using a plastic wedge tool on the outer side. I found that the third tube up from the bottom connection was broken off. At first I thought why would a circuit that is not drawing anything cause a shutdown. I checked all of the coils went back to that one and yep it spiked. I took a look at the video on U tube.pulled the board and removed the coil and jumped out the 2 outer pins.
                                    Picture came up and I cannot see the missing tube.
                                    Thanks for the info and the link to the video, it helped out a lot.
                                    RJ
                                    • PopsCaps
                                      Sony Bravia KDL-40V2500 that will not power on
                                      by PopsCaps
                                      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                      I do not hear any sound and I cannot see any backlight.
                                      I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                      03-25-2025, 11:23 AM
                                    • mauda
                                      Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                      by mauda
                                      I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                      Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                      05-21-2023, 11:56 PM
                                      HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                      This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      09-06-2024, 05:27 AM
                                      HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
