Dell 2208wfp hissing
  • reabbott
    • Jul 2012
    • 10
    I have 3 of these, all with the same issue, 3 seconds to blank. I replaced the burnt out caps on all 3 screens, two of them came back alive. This is an image of the 3rd one.
    In the image, the red circle is the only burnt out cap that i replaced. The blue circle is where im getting the hissing sound from.
    I turn on the screen, get the high pitched hiss, the screen goes blank after a couple of seconds, the hissing stops. If i do this in the dark, i can actually see the wires leading from the board glow a blue/purple colour, this is accompanied by a chemical burning smell. I havent messed too much more than this, i understand that the currents involved could be tremendous. Does anyone have an idea as to whats happening ? is there such a thing as a dead electrolytic cap that doesnt show obvious visual cues ? Any advice is very welcome.
    Thanks in advance.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Dell 2208wfp hissing
    Does the hissing happen when the wired are disconnected? First I would try one plug at a time to see if the bulbs light in that socket. I would say you have a direct short bulb socket to ground to cause this.
    • reabbott
      • Jul 2012
      • 10
      I messed a little more. I plugged each bulb into their own sockets, same result, i plugged swapped them around (so bottom bulb in top socket, top bulb in bottom socket) and i get the hissing from the same wires, not the same socket. So this points to the problem being the actual bulb and not the socket. I have never replaced a bulb and would be quite sure that repairing a bulb probably isnt possible.
      • drpj23
        • May 2012
        • 528
        Bulb replacement isnt impossible, you just have to be careful for they are very fragile. If you cannot find replacements find a busted LCD and steel the bulbs out of those.
        And to your first post, caps can definitely be bad without a visual sign (such as bulging).
          Yes, the Dell 2208 with bad lamp wiring and also bad transformers, fix about a dozen of these, all with bad wire that just barely hanging on to the lamp's ends.
          http://s807.photobucket.com/albums/y...cpZZ1QQtppZZ20
          • heavymachines
            • Mar 2011
            • 1028
            Also wanted to mention you can get bulbs of any size you want from www.ccflwarehouse.com/ I have had no issue with their bulbs...and also on that note the first few you change are a pain to do but after you do a few of em they do get easier....
            • heavymachines
              • Mar 2011
              • 1028
              Also the very first two i have ever done i destroyed due to slightly ripped tabs be very careful of those tabs when you unsnap the frame... I learned the hard way, you may wanna practice on a monitor you don't care about, like a little 15 incher er something.... and if you get it back together without lines in the screen you have done well...
              • reabbott
                • Jul 2012
                • 10
                Awesome replies, and thankyou for the photobucket. I pulled the bulbs out, slowly, broke one of them. The ends didnt look burned like yours did though, ill pick up some replacements from the cflwarehouse and attempt my first bulb transplant I found the same screen on ebay with horizontal lines, i could in worst case scenario, buy that, and swap the lcd panel with my good panel. Experiment continues with the aid of your photobucket !
                • heavymachines
                  • Mar 2011
                  • 1028
                  and if they don't have the size they will make it for you.....
                  • Bosse100
                    • Dec 2012
                    • DK
                    @reabb0tt
                    Dit you solve the problem ?
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • master3112
                      by master3112
                      07-29-2025, 01:55 PM
                    • repair-it
                      TOSHIBA DLP 52HM95 How to reset timer module on bulb
                      by repair-it
                      I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                      Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                      10-11-2023, 07:18 PM
                    • F R 2568
                      Dell Latitude 5420 does not start (no post) need help to find the reason why
                      by F R 2568
                      Hello all,
                      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                      If the laptop is only connected to the AC adapter (battery removed):
                      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                      The power/battery...
                      01-08-2025, 05:45 AM
                    • Abrith
                      dell 5391 blank and topspeed fan, anyone have bios bin file
                      by Abrith
                      dell 5391 servis tag GJJBJW2. ic type MX25L8006E
                      12-07-2024, 07:00 AM
