possibly lightning struck ?
  • flamike
    rookie
    • Jan 2012
    • 25
    got a couple possible lightning struck tvs,sanyo DP26670 and insignia NS LTDVD26-o9,neither have main voltage to big cap 60 volts ac instead of 120ac,replaced 2 EMI suppression capacitors and bridge rectifier and main board on sanyo with no luck same blinking red light,insignia light is steady blue any ideas ?
    Re: possibly lightning struck ?
    You are measuring main voltage incorrectly, you should measure with your meter on DC volts. Lightning damage can't cause that kind of failure.
    • flamike
      rookie
      • Jan 2012
      • 25
      hey I get same on dc,seems like ground is missing,or maybe im not doing it right
        Positive on positive lead of cap, negative on negative lead of cap?
          OK, on the AC primary side, the negative leg of the large DC filter cap (the one with 250 or 450Vdc rating) is the circuit ground of the primary side.
          The cold side (secondary side), the chassis is the circuit ground for the secondary circuit.
          • flamike
            rookie
            • Jan 2012
            • 25
            thanks,your right 169.9,was trying to use ground of power supply,either ac or dc
            • Sam “Captain” W. C
              Corsair RM650 ATX, possibly struck by lightning
              by Sam “Captain” W. C
              Just starting out in electronics repair and teaching myself as I go.
              I have here a Corsair RM650 ATX PSU, which I'm treating as a learning project that if successful may be used in my PC.
              Fuse was blown, probable power surge from lightning, followed the circuit and found, a dead relay and all the diodes and resistors around the bridge rectifier shorted. Rectifier and MOSFETs seem fine on the LCR.
              Also found these tiny diodes on the other side, a few shorted, the rest seem fine. But they're not all marked as Zener on the pcb. So I'm unsure what these should be replaced with....
              06-12-2024, 09:52 AM
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • lolich112
              RTX 4070 Ti GAMING X TRIO 12G All displayports failed after lightning struck
              by lolich112
              Hey, I have this GPU (MSI GeForce RTX 4070 Ti GAMING X TRIO 12G). After a lightning struck all dispaylports don´t work anymore but the one hdmi does in fact function properly. Has anyone a suggestion, what the error may be? Is it the GPU core itself that is damaged or is it a simple replaceable chip that is fried?
              10-01-2023, 10:51 AM
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
