Philips 42PFL7422D backlight troubles
    Re: Philips 42PFL7422D backlight troubles
    How did you place two leads on three pins?
    • ztu165
      • 87
      No I placed the leads on the outer pins not the middle pin.
        That indicates a defective driver IC in my opinion -- that 24/28 pin device in the middle of the board. Also test between the large tab pin (electrically connected to the middle pin) and each of the smaller pins.
        • ztu165
          • 87
          So the IC is what's causing the very slight flicker?
            0.04 ohms is nothing to be concerned about, the difference in the solder flux or quality of solder could easily cause that, now I would ask, are you using ohms, or Kohms?
            • ztu165
              • 87
              Ohms.
              • ztu165
                • 87
                Can anything else besides the backlight inverters cause the flickering? Not really flickering it's more like lines across screen moving upwards like waves or like a cascade of water. Probably regular person wouldn't be able to tell but I have same TV but with ambilightsnin the back and I can tell they are there.
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  #28
                  Just wanted to chime in and clear up the matter of measuring the fets. If you read my post from the link that I posted earlier, I explained that reading ohms across these fets will tell you whether or now the driver chip is good or bad. With the driver chip off of the board, and if you take the same measurement, you will read 10K ohms becasue there is a 10K resistor that is in parallel with that fet. So... that means that the fet reads open and the 10K in parallel with the fet reads 10K. But... at the same time, that driver chip is in parallel to both of these in which brings down the resistance to 8.5K As this chip goes bad, the resistance will drop. I have seen some work though they read 8.25K.
                  Now, since you're saying that the problem is more of a rolling, changing faint line, I'd suggest posting a picture of it.
                  • ztu165
                    • 87
                    Thanks for coming back and clearing things up, I'd greatly appreciate your help. I am having problems getting the lines to show up on pictures and I tried video taping but you can't see them. I wish I new which were the original inverter boards that came with the TV so I can order them. It's no just one or two lines, but a whole bunch, they are thin and cascade down from the top. They look transparent and they are not visible if the image is not white or any light color.
                    • Dgtech
                      E. Technician
                      • Apr 2009
                      • 1462
                      • Steeler
                      #30
                      I'm inclined to advise you to try reseating all ribbon cables to the t-conn board. I'm trying to give you cheaper things to try than changing out the inverter boards. New boards would make this fix very expensive and almost not worth it.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        On mine ended up being the two big ceramic resistors were open.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          ...on the power supply.
                          I have just picked up another one of these and I have re read these posts.
                          One FET on the slave inverter is 11.3 Ohm, all the rest are 8.5 Kohm.
                          Should I replace only that transistor, or the IC can be bad also?
                          • Dgtech
                            E. Technician
                            • Apr 2009
                            • 1462
                            • Steeler
                            #33
                            It most likely is the IC that has failed. Fets usually fail completely shorted. Of course, if its easier to pull the fet and check across the pads then go for it.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              It was the IC, FET it was fine. Thanks
                              TV is running.
                              • cheeky2
                                Help with bypassing the OZ9928SN inverter ic from I470H1-20A MASTER LG 47LG5000
                                by cheeky2
                                Merry Christmas
                                Does anyone know how to bypass the protection ic OZ9928SN on a LG 47LG5000 inverter using a I470H1-20A MASTER pcb?
                                Pictures attached
                                Thanks in advance...
                                12-26-2024, 05:25 AM
                              • x_orange90_x
                                by x_orange90_x
                                01-29-2025, 09:24 PM
                              • alro7779
                                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                by alro7779
                                Hello, guys!
                                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                09-14-2025, 12:25 AM
                              • G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                by G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                It does power up when pressing the power button.
                                I already try the power button while plugin the plug with no result.
                                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                Could this be an PSU or eMMC issue ?
                                07-19-2025, 03:43 AM
                              • Gentian
                                APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                by Gentian
                                I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                03-06-2023, 07:07 AM
