Samsung LN32A550 Backlight Issue
  • stith
    • Oct 2012
    • 24
    • usa
    Re: Samsung LN32A550 Backlight Issue
    When looking inside the panel with the lights on, it seemed like two or so light halfway. I'll work on getting some more images of behind the lcd panel today. I was also thinking maybe a shortage of power. The 24 volts might be good but at what wattage or current draw. .not sure i have the instruments to measure that.
    • stith
      • Oct 2012
      • 24
      • usa
      More information! In the form of pictures...
      Also, no capacitors between lamps?
      • cheebster
        • May 2008
        • 360
        just wondering, did you try to connect 1 at a time the ccfls on the inverter, do the ccfls light up this way ? it might be 1 ccfl that is bad that the inverter is struggling with..
        like, connect first, then try just the second one, then third.. check each of them
        • stith
          • Oct 2012
          • 24
          • usa
          This is what I just tried. Only the top 4 lamps would light. I also tried it with no lamps and the inverter board still made a static noise from near the middle top of the board.
            You could have a loose connection near there then - try reseating all lamp connectors, make sure they are secure, etc.
            • tibimakai
              • Jan 2012
              • 3680
              Did you measure all 8 FET Transistors?
              • stith
                • Oct 2012
                • 24
                • usa
                #27
                With all lamps unpluged, the noise persists. I can reconnect them all and see what i dont think it will change.
                  So what resistance reading on each pair of the Pink and White wires are you getting, I am expecting it to be around 3K or more since U-shape lamp will need really high voltage to drive than the straight lamp. And by the way, the lamps stay half way lit like that without going into shutdown?
                  • stith
                    • Oct 2012
                    • 24
                    • usa
                    #29
                    I have a basic meter for testing resistance. I was getting about 2.5k ohms on the connectors. Also the tv stays on as is with half the lamps half way on. I did a sniff test for burnt components and it checks out fine.
                      It is really strange that it did not go into shutdown mode due to lamps not fully lit. Another thing that does not make sense either is that if you have just one lamp connector connected, I would expect you to see it fully lit for a second (before it goes into shutdown mode) since it will be the only one that draws the current.
                      I wonder what will happen if you change those 6 caps on the inverter board.
                      • stith
                        • Oct 2012
                        • 24
                        • usa
                        #31
                        Is there a factory reset button mash i can do for this lcd? Maybe a setting is bugged out.
                          Service Mode (1):
                          TV in standby.
                          On remote: INFO - MENU - MUTE - POWER.
                          Service Mode (2):
                          TV in standby.
                          On remote: MUTE - 1 - 8 - 2 - POWER
                          Try either - see which works. Second one I think is US only, first one works on most Samsung TVs.
                          When in service mode look for factory reset option.
                          • drpj23
                            • May 2012
                            • 528
                            If that doesn't work ..... how do all those HV transformers check out?
                            And two, I second also checking the FETs (as tibimakai said) and possibly changing those caps (as budm said)
                            Would the ballast caps be under the inverter board?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              I'm on the inverter transformer failure. Just repaired a Westinghouse 32" LCD that Both transformers Khmer good but one was burned on the inside. Not visable on the board. Similar instance. Is one transformer getting warmer than the others?
                              • stith
                                • Oct 2012
                                • 24
                                • usa
                                #35
                                Sorry for the short hiatus. I tried the factory reset (the MUTE - 1 - 8 - 2 - PWR worked) but came back the same way it was already.
                                I can try measuring the FETs...
                                I don't have replacement capacitors to replace the 6 that are on top of the board so I don't think I'll do that just yet.
                                I just noticed these marks on my board. I circled them with red on the picture. Could this mean some of those components failed and damaged the board? Or is it just bad manufacturing...I'm really suspecting the inverter board to be the culprit here and I think I might just need to replace the whole thing.
                                  It looks like someone had replaced the transformer and the caps, they are solder flux.
                                  • stith
                                    • Oct 2012
                                    • 24
                                    • usa
                                    #37
                                    I had gotten this TV from newegg.com a few years ago. It wasn't a refurbished TV.
                                      More than likely, those caps and transformers are hand-retouched as they are not designed to be surface mounted by machine. But it makes me wonder how much additional cost that brings to say using SMD caps and transformers.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        #39
                                        darfon inverter.
                                        bad transformers.
                                        at least most are cheap and availible.
                                        • stith
                                          • Oct 2012
                                          • 24
                                          • usa
                                          #40
                                          I order a new board of the exact same manufacturer and number for $15.99. Should be here mid next week. See you all then.
                                            09-07-2024, 05:50 AM
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
                                          • max789
                                            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                            by max789
                                            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                            I made the following tests:
                                            1. Disconnected the main board from Power Board = backlight works.
                                            2. Connected the main board and disconnected the T-Con = backlights does not work.
                                            So I ordered a main board from Ebay also BN41-02156A but from...
                                            01-18-2024, 06:56 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Manucsl
                                            QE65Q800TATXXC Samsung TV Issue
                                            by Manucsl
                                            Hello.
                                            My TV is a QE65Q800TATXXC Samsung TV.
                                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                            Any ideas to check would be very appreciated 😊
                                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                            02-19-2025, 07:47 AM
