Philips 47pfl5603d/27 noise and then screen goes out
  • Got sol
    • Oct 2012
    • Usa
    Hello
    Suddenly my Philips 47" TV model 47pfl5603d/27 starting acting up. It is about 4 or 5 years old.
    I noticed a "fuzzy" noise like static and then the screen fades until it goes black. The sound is still there. Shutting the TV seems to help but the time between the incidents varies greatly.
    Based on my limited searching it seems like it could be a power supply issue. Any idea of cost to repair the unit? I am fairly handy but this doesn't seem like something I'd like to try myself.
  • drpj23
    • May 2012
    • 528
    Re: Philips 47pfl5603d/27 noise and then screen goes out
    Can we get pictures of the power supply via the attachments feature?
    Front and back (since you replied to that other post too)
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • courtcircuit
      Philips HTS8000 home cinema noise problem
      by courtcircuit
      Hello
      I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
      Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
      Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
      I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
      Removed each of tyhe boards
      02-08-2025, 08:22 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
