Lg M2362D white screen replace lcd display
  • giammago
    • Oct 2011
    Hello to everyone.
    My friend gave to me this monitor/tv that turns on and goes completely white. You can't access any of the OSD menus or anything.
    Before gave to me, He bringed it at LG assistance where they said to change the lcd display, but it was too expensive.
    Looking to the suggestion of this wonderfull site I checked the pico fuse in the t-con board integrated in the siplay, but there is contimuity.
    So i started looking on the net for a LM230WF1-TLA3 lcd display replacement with no great luck.
    Hovever I found some used LM230WF1-TLA5 and LM230WF1-TLB3 at good price (especially tlb3).
    I was wondering if these lcd replacement fits to my monitor.
    I attach displays specs:
    LM230WF1-TLA3
    http://www.panelook.com/LM230WF1-TLA...eter_4962.html
    LM230WF1-TLA5
    http://www.panelook.com/LM230WF1-TLA...ter_13597.html
    LM230WF1-TLB3
    http://www.panelook.com/LM230WF1-TLB...eter_4964.html
    according to specs the LM230WF1-TLB3 is very similar ti the LM230WF1-TLA3 (except antiglare surface) and the LVDS connector is equivalent according to LM230WF1-TLA3 datasheet
    LCD connector(CN1) : GT103-30S-H23 LSC) , IS100-L30B-UJU)
    Mating connector : FI-X30H and FI-X30HL (JAE) or Equivalent
    Do you think they are compatible?
    Thanks in advance
    Re: Lg M2362D white screen replace lcd display
    I would try new T-CON board before replacing the whole screen, just make sure the P/N on the bar code matched what you have.
      master hoarder
      • May 2008
      • 12175
      Before trying anything else, first they re-seating the LVDS connector several times. If this doesn't fix the problem, post some pictures of the t-con board. Sometimes, the fuse won't blow on these, but they can still have a fault.
      Also, when the TV is turned ON, check what voltage is going to the fuse on the t-con board. It's usually 3V to 5V, but it can also be more (depending on the design). It would be silly if you changed the panel and then found that the new panel didn't work either because there was no power going to the t-con board.
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • harp
        White screen repairs
        by harp
        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
        05-13-2024, 03:43 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • lerros
        Dell P2417H white screen display
        by lerros
        Hi there,
        I have a Dell monitor model P2417H white screen display. The panel is samsung LTM238HL05. I measure test points and don’t anything like VGH, VGL, … still have 5V. Please suggest me some thing.
        Thank a lot!
        05-21-2024, 09:39 AM
