Akai LCT3201AD
  • trains58554
    • Apr 2012
    • 55
    Re: Akai LCT3201AD
    I have checked fuses f1 and f2 in the last picture. Are there more that I did not see? I also just saw f3 and checked it and it is good.
    • trains58554
      • Apr 2012
      • 55
      Re: Akai LCT3201AD
      I did some more testing of sorts. I unpluged all of the ccfls and then powered up the tv and it works. I also tried it with just one ccfl and it shut down. I also tried with just one half and it just shut down.
        Re: Akai LCT3201AD
        The inverter circuits will shutdown if during the first 3 seconds if it does not detect one lamp or more do not fire up, or if it detects that any one of the lamps fire up but does not stay on, or of the lamp draws too much current. It will also shut down if the circuits is drawing too much current due to shorted MOSFET's, bad transformers
        • sumilumi
          700mv ripple on Akai Sampler linear supply
          by sumilumi
          Hi fellow troubleshooters. This is my first post on badcaps. I've recently setup an electronics workbench. i'm also building a studio with old equipment bought faulty at low cost.
          I've been into electronics since the mid 80's and particularly in the last few years though only getting hands on with repairs now. My knowledge gaps are significant so I'll be posting here to seek guidance advice and general practical applied learning.
          On my bench today is an old ca. 1993-95 Akai hardware sampler. This runs on both a linear and Smps supply. Both are getting on in age and ripple...
          01-02-2022, 10:12 AM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          Today, 07:14 AM
        • CMCM
          Russound CA4 Power Supply Repair
          by CMCM
          Hello Everybody,
          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
          The outputs marked 12v and 20v are all measuring only 1v.
          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
          The capacitors physically look clean (no bludgesor leaks) and...
          07-03-2025, 01:12 PM
