Magnavox 32md359b/f7 White Screen and with sound only
  • YEROC37
    • Sep 2012
    • 119
    Re: Magnavox 32md359b/f7 White Screen and with sound only
    Locating cap now
    • YEROC37
      • Sep 2012
      • 119
      33.9 V is what I get on that cap tom,
        Check your meter battery, something does not seem right. Low battery could cause high readings. That should be 15.7V; it's provided by the 16V supply.
        • YEROC37
          • Sep 2012
          • 119
          That I'm sure is high if your saying it should be around 15v, so do you think something is shorted
          • YEROC37
            • Sep 2012
            • 119
            I just checked several household sockets and batteries and readings are perfect
              It definitely seems bad and maybe that's the cause of the problem but I sure hope it hasn't damaged anything! The crappy self-oscillating power supply could cause this I suppose. This is what happens when you get bean counters to design a TV.
                OK here's a simple test which will be go/no go on your meter's accuracy. CAREFULLY check voltage across CN602 - it's the red/black running from PSU to inverter. It should be around 165V. I'd say 10V either way is fine.
                • YEROC37
                  • Sep 2012
                  • 119
                  tom, I checked my wall sockets, checked cords to verify...I just read 334v across red and black CN602
                  • YEROC37
                    • Sep 2012
                    • 119
                    on my wall sockets I'm reading 118, on other devices they read correctly...so I'm not getting this boost of volts I'm suppose to be getting that your mentioning ...I understand what your saying but your correct it does seem high
                      Something is very, very wrong. You are living in a 115V/120V country right? That should be at 1.41 * line voltage or around 162V. I am very suspicious of your meter right now - it just doesn't seem right. Can you please swap the battery, just in case. How old is the meter, and has it ever been subject to an overload on the voltage ranges? Right now, your meter seems to indicate your line voltage is about 235V. It is possible it is just inaccurate on the DC voltage range, as measuring AC voltage is different. BTW, which meter is it? I don't think I ever asked.
                      • YEROC37
                        • Sep 2012
                        • 119
                        tom black and white power plug going into tv reads 118, when I go to black n red at CN602 it reads 334v, I have switched batteries and meter is only a few months old...as far as overload wouldn't it give me incorrect readings on most readings because it seems to be correct on all other test?
                          This may be a d'oh moment for myself. Are you testing across the red and black, or from one lead to chassis? It should be across red and black. You have tested a new AA battery? Does it read 1.5-1.6V on the 2000m, 20V and 200V ranges?
                          • YEROC37
                            • Sep 2012
                            • 119
                            I'm in Virginia lol
                              Maybe Virginia is different from the rest of the Union in that it uses 230V ...
                              • YEROC37
                                • Sep 2012
                                • 119
                                Yes I'm reading all wires directly to both probes but on those connections it reads that high, but on walls and batteries they are within the correct ranges
                                  Hmm. If you try on the 600V or 1000V range (whichever it has), does it read correctly?
                                  • YEROC37
                                    • Sep 2012
                                    • 119
                                    Now remember we started the pilgrimage here in Jamestown so I think we understand some currents here lol
                                    • YEROC37
                                      • Sep 2012
                                      • 119
                                      LOL..I'm checking correctly tom, but that burst of extra voltage is coming from somewhere
                                        Just need to be certain, it really doesn't seem right. 118V would be rectified to 167V; that's how a rectifier works. There is no PFC boosting circuit in this TV that could cause it to increase like that. It must be the meter, but I don't know why! Please try testing on the other ranges just to be sure.
                                        • YEROC37
                                          • Sep 2012
                                          • 119
                                          I got ya, I've check everything I can tom.........I'm stumped as you probably are
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • EazyBone
                                            Sharp LC-65Q620U White Screen
                                            by EazyBone
                                            Another TV topic!!
                                            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                            08-21-2024, 12:56 PM
                                          • hcinne
                                            Dell G15 ryzen edition black screen 2 amber 1 white
                                            by hcinne
                                            I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                            07-23-2024, 07:56 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
