Magnavox 32md359b/f7 White Screen and with sound only
  • YEROC37
    • Sep 2012
    • 119
    Re: Magnavox 32md359b/f7 White Screen and with sound only
    I don't see the VDDG at all,
      Sorry my fault, I wasn't thinking when I said something like VDDG, just added a random letter.
      • YEROC37
        • Sep 2012
        • 119
        Anything is ok at this point, so Is this french toast or maybe something else we can try?
          Each of the flexes has an IC chip attached to it bonded in the flex. If the chip goes wrong, you get a bar on the screen. Usually not all the chips go wrong at once so it can point to a more common fault - such as a processing board fault (HDMI board in this instance.) Thing is, the power supply in these things are so unstable (self-oscillating, without any form of intelligent IC to control it), it's possible they passed a surge or similar through to all the drivers and toasted them simultaneously. Apparently someone had a similar problem with an LG plasma (which also uses chip on flex... half of his screen got fried due to a common fault - I wouldn't be surprised if all could be damaged at once.) I'm not sure where to go from here, there are no fuses on the board to test, all the voltages appear to be there, it's just not working.
          • YEROC37
            • Sep 2012
            • 119
            the fact that I play with the cables and putting them in or at right now as a last minute thing to do wouldn't make any difference....I see screen get dark, boxes appear, lines, etc... LOL..I know I'm fetching but I know I could possibly use this thing for parts..caps, etc...
              If you are seeing something briefly when you play with the cables have you tried the trick in this video?
              http://www.youtube.com/watch?v=vCExlSnG4yY
              • YEROC37
                • Sep 2012
                • 119
                Well, taken everything off TV, boards, DVD drive, etc... Maybe they can become parts for something or I can make something interesting later for grandkids lol
                • YEROC37
                  • Sep 2012
                  • 119
                  More than likely the inverter board is still good correct?
                    Yes, and the PSU is probably good. The HDMI board would be the only questionable board in my opinion.
                    • YEROC37
                      • Sep 2012
                      • 119
                      HDMI eh? I had TV out by the front lawn and just went and grabbed it lol...I can put everything back together again, but how likely is it
                        Thing is the only fault with that would be very difficult to trace without an oscilloscope. You could replace the board but I'd expect it's fairly pricey.
                        But you'll soon be checking Craigslist or similar sites for faulty TVs... once you get bitten there's no going back! Try and pick up a 32" Samsung of the R87 series - they have common issues with bad caps and are generally nice easy fixes.
                        • YEROC37
                          • Sep 2012
                          • 119
                          Ok cool, I seen a hdmi board for 17.50 on ebay, seller has excellent rating and policy
                            Well if you feel like taking a chance go for it. It could be your problem and it would be a nice easy fix.
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • EazyBone
                              Sharp LC-65Q620U White Screen
                              by EazyBone
                              Another TV topic!!
                              I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                              The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                              Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                              08-21-2024, 12:56 PM
                            • hcinne
                              Dell G15 ryzen edition black screen 2 amber 1 white
                              by hcinne
                              I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                              07-23-2024, 07:56 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
