Goodmans 26" LCD TV No picture
  • Loobylou
    • Feb 2017
    Re: Goodmans 26" LCD TV No picture
    I know this post is quite old, however, we are having the same problem with our goodmans tv. I was just wondering how capicitators are change?
    • ducky29
      • Dec 2015
      • 370
      • Europe
      bro make a new post instead
      • sordids999
        SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
        by sordids999
        Hi
        Really stuck on this TV
        I'm thinking it's a bad screen ?
        Voltages all seems good
        Tcon 12v ok
        Remove one tcon cable at a time no half image on the screen just backlight and no picture
        even tried the tape trick still no luck
        Thanks...
        05-12-2025, 10:36 AM
      • stinger
        Samsung UN70TU6980FXZA no sound no picture but does have backlights
        by stinger
        When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
        04-17-2024, 03:06 PM
      • DXseekerMO
        TCL 55US57 backlights, no picture.
        by DXseekerMO
        So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
        The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
        Power Supply, main and T-CON board are working.
        Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
        Unhook FFC from left side...
        09-18-2021, 03:56 PM
      • Davidhames
        KDL-70R550A Peeled off LCD Tabs on left side and perfect picture for 5 minutes
        by Davidhames
        Hi Guys,
        Thought I might try and seek advice on an issue I am having, I got this SONY tv for free that was having some dark greenish colouring, I replaced the T-CON and too my suprise the TV would not boot - I would get 5 blinking red LED lights. I dug deeper into this forum and someone mentioned the fact that it might be the tabs that connect to the LDC panel, and peeling them off should bring back a clear image. I tried this on the side of the T-con that was causing the tv to not boot when plugged in (left) and wow a perfect picture and was booting up fine! All was well and good...
        02-23-2022, 08:21 PM
      • htv239
        LG UH8500 Backlight Troubleshooting Help
        by htv239
        I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
        Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
        What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
        10-11-2021, 01:53 PM
