lg 37lc2d power issue.
  • jmfatigato
    • Sep 2012
    • usa
    First of all, I must admit that I am in owe of all the knowledge people on this site have.
    I am a pure beginner.
    I have a 37" LG. Older model.
    Green light started to flash about 15 times, and would turn on.
    Was informed on this site to either replace bulging capasitors or get new power board for my model.
    Well. I bought a new Power Supply Module from a company suggested by LG.
    I installed it. Easy. Unscrew old. Install new.
    Problem?
    Still flashing green light 15 times. Then takes about 8 to 10 minutes to turn on.
    But when on, it remains on, until I shut it off.
    But I dont want to leave it on forever.
    Now I was told to buy a Mother Board, or main board.
    Is it worth it? So far I have invested 70.00. Love the T.v.
    Any suggestions on board replacement, or ideas?
    Thank You
  • retiredcaps
    • Apr 2010
    • 9271
    Re: lg 37lc2d power issue.
    1) The above sounds like classic symptoms of caps having high ESR (ohms). As the TV warms up, the ESR in the caps fall and the circuit works.
    2) Post clear focused pictures of all your boards following my sig file below exactly.
    3) Do you have a multimeter and know how to use it to measure DC voltage?
    --- begin sig file ---
    --- end sig file ---
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • notallbad
      TCL 55RP620K power board issue
      by notallbad
      Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
      0% p_dim at 1.65v and a_dim at 1v
      50% p_dim at 3.3v and a_dim at 1.65v
      100% p_dim at 3.3v and a_dim at 2.88v
      Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
      Leds are 2 rows of 15 6v leds.
      On inspection of the power board found diode MBR3200 shorted so replaced with...
      07-12-2025, 05:45 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
