42LG50 Won't Turn On
  • craig34
    • Sep 2012
    • 9
    SUMMARY
    An LG 42LG50 that won't turn on (though the standby light does turn on).
    WHAT I HAVE DONE
    I'm totally new to this so I'm sorta fumbling around as to where to go. I ordered a replacement power board, but wanted to see what else that I could do while I awaited it. In research, I found that often times a faulty main board is to blame, so I wanted to see if I could figure out if that were the case with mine.
    I went through the instructions located in this post and tested the voltage regulators on the main board. I have attached photos of this main board.
    QUESTIONS
    1. I'm hoping that someone can look over the results that I found, as well as the attached photos and datasheets, and let me know if I am correct in saying that IC704 is bad but that IC703 and IC707 are good.
    2. I had a hard time finding the correct datasheet for IC709 and was hoping someone might be able to assist me in determining if that is bad or good.
    3. Finally, I'm also wondering if I should have tested any other regulators that I did not test.
    VOLTAGE REGULATOR TEST RESULTS
    PCB Designation: IC703
    Line 1 of IC: AZ1085S
    Line 2 of IC: 3.3E1
    Pin 1: 00.1
    Pin 2: 3.29
    Pin 3: 5.10
    PCB Designation: IC704
    Line 2 of IC: ADJE1
    Pin 1: 1.384
    Pin 2: 2.62
    Pin 3: 5.11
    PCB Designation: IC707
    Line 2 of IC: ADJE1
    Pin 1: 00.1
    Pin 2: 1.245
    Pin 3: 3.29
    PCB Designation: IC709
    Line 1 of IC: SC1565I5M
    Line 2 of IC: 0816
    Pin 1: 5.05
    Pin 2: 5.05
    Pin 3: 00.2
    Pin 4: 3.37
    Pin 5: 1.195
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LG 42LG50 Won't Turn On
    Originally posted by craig34
    QUESTIONS
    Thanks for doing some research and homework first. It helps us when you use my format to post things.
    For IC704, look at line 2. It says ADJ. That tells you it is an adjustable regulator.
    For an adjustable regulator, the formula is pin 1 + 1.25V = output of pin 2. 1.384 + 1.25 = 2.634 (close enough to 2.62 => I use a +/- 1% tolerance).
    http://pdf1.alldatasheet.com/datashe...I5M-X.XTR.html
    Hint, your package is a TO-263-5 (page 4). Pin 5 should tell you if the output voltage on pin 4 is correct or not. In addition, I circled two resistors R116 and R117 (in yellow). Their values will help you determine with is the correct output voltage as the forumula presented on page 5 in the ADJ column.
    IC709 is left for you to check.
    Yes. Always. It is easy to check and only takes a few minutes. I count 11 on the picture (circled in red) with the possibly more on the backside of the board.
    --- begin sig file ---
    --- end sig file ---
    • craig34
      • Sep 2012
      • 9
      Re: 42LG50 Won't Turn On
      Thanks for your help and the clarification about the adjustable regulators, that makes sense.
      I'm going get the readings on the rest of the regulators this morning, but was wondering if you could tell me if the TV symptoms (won't turn on, but standby light will) are even consistent with a bad regulator in general?
      • craig34
        • Sep 2012
        • 9
        I'm a quick study but I fear that my lack of (really any) knowledge in this area is catching up to me. I can see that the formula to determine the output voltage of the 5th pin is 1.200(R1 + R2) / R2, but I can't figure out how to determine the values of R1 and R2.
        I understand that those values correlate to the resistors that you circled (they are actually R716 & R717, not what you had written) but I'm not sure how to determine those values. I searched the datasheet that you provided as well as the internet in general but I'm having a hard time finding anything that makes sense to me.
        I'm also unsure as to how to determine which is R1 and which is R2, though based on the Typical Application Circuits chart - I suspect that R716 is R1 and R717 is R2.
        • retiredcaps
          • Apr 2010
          • 9271
          There should be a code on each resistor telling you the value. For example, 202 means 2000 ohms.
          You should also measure each resistor with your multimeter to verify.
          http://www.learnabout-electronics.org/resistors_07.php
          On my monitor they looked like R116 and R117.
          Put your multimeter on continuity test mode and you can ohm or buzz it out. R2 will have one leg on the ground rail.
          • retiredcaps
            • Apr 2010
            • 9271
            Yes, a bad regulator could prevent the TV from powering on.
            When you plug the TV into the AC outlet, 5V SB is automatically on. That should mean the standby light is on. When you press the power button, the main board is responsible for turning that power LED to green. If any component on the main board is bad, then the power LED will stay in standby mode.
            Vizios seem to be plagued with bad voltage regulators and "won't turn on" is one of those symptoms. I know your TV is not a Vizio.
            • craig34
              • Sep 2012
              • 9
              WARNING: Likely obvious newbie question coming up!
              Is there a way to, at a high level, determine whether the main board is good by measuring something on the power board (which appears to be next in line)?
              • tibimakai
                • Jan 2012
                • 3680
                ...like the easy button from Staples?
                • craig34
                  • Sep 2012
                  • 9
                  Haha, something like that. I was more thinking that maybe there was a way to disconnect something and test the power on the main board, etc. I'm a programmer and I'm approaching this like that - trying to be able to identify roughly where the problem is, so I can focus my testing.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Not really, the main board does a lot of things and it is hard to test them all in a standalone environment. The main board does send the commands PS_ON (power on) and BL_ON (backlight on) to the power board and you can check for its presence on the connector between the two.
                    • craig34
                      • Sep 2012
                      • 9
                      How would I do that? Do I need anything more than a multimeter?
                      If I were to test for those commands and find that they are being sent from the main board successfully - would that prove that the problem is with the power board?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Using those pins go "hgh". That is from 0V to something > 3V when you press the on button. Some boards will have a legend right by the connector with PS_ON, BL_ON. I don't know if yours does or not since you haven't provided a picture of the power supply (hint).
                        Not really. The main board might be sending PS_ON to the power board and the power board is trying to start, but something on the main board is dragging it down. I experienced that first hand with a shorted ceramic capacitor on the main board. Details at
                        https://www.badcaps.net/forum/showthread.php?p=114994
                        • craig34
                          • Sep 2012
                          • 9
                          Here are photos of the power board.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            The two connectors in the top left hand corner appear to have a legend, but are obscured by the cabling.
                            That is where you may find PS_ON, BL_ON, etc.
                            • cubytus
                              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                              by cubytus
                              Hi to all,
                              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                              01-10-2024, 01:26 AM
                            • otaku_nut
                              Vizio E701i-A3 fixed but now has red vertical line
                              by otaku_nut
                              Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                              08-19-2025, 06:11 PM
                            • TrueSword88
                              Kogan - KALED65XU9220STB - Blue Vertical Line
                              by TrueSword88
                              Hi all.
                              I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                              The line just happens to coincide with the end of COF and start of the next COF (attached).
                              The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                              Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                              Hoping to fix...
                              05-05-2023, 04:28 PM
                            • FALKLAN
                              Running Line Voltage and Integrating LED Pods - Automotive
                              by FALKLAN
                              Howdy everyone! I hope all is well where ever you are!
                              I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                              I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                              02-05-2025, 12:30 AM
                            • mindoverflow
                              ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                              by mindoverflow
                              hello,
                              there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                              I changed pads and thermal paste.
                              I run mats test but it is reporting 0 errors.
                              I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                              After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                              02-09-2022, 03:22 PM
