LG RZ42PX11 - getting rid of sparklies by adjusting v up and V down
  • Cornboats
    Dave
    • Oct 2010
    • 232
    I've had to change y-sus and Z sus boards now sets got sparklies (small coloured spots) all over the screen like a rash.
    I read previous threads and consensus appears to adjust v-up and v down pots. I read in the manual that this could only be done using a scope. My scopes only 20 mhz. Anyone done this successfully. Is it just a case of fine adjustment a bit at a time. Do you move both pots in the same direction or 1 at a time?
    Any helpful advice would be gratefully accepted.
    Re: LG RZ42PX11 - getting rid of sparklies by adjusting v up and V down
    Needs a new control board to fix sparklies - or updated firmware. AFAIK, not fixable by tweaking V_up or V_down.
    • Cornboats
      Dave
      • Oct 2010
      • 232
      Thanks for replying. I haven't got a spare control board so lets go down the firmware route.
      How do I upgrade?
      • eccerr0r
        adjusting a 12V inverter to 24V
        by eccerr0r
        Anyone hacked a 12V inverter for use at 24V?
        Wonder how much of a problem it is to do such. Other than the fan that seems to be a 12V unit that will need to be replaced with a 24V unit, as well as input filter capacitors that tend to be rated at 16 to 25V that will likely need to be increased to at least 35V, any other possible issues that need to be addressed?
        11-03-2023, 04:24 PM
      • dragometin
        LG RZ42PX11 Flickering / Flashing
        by dragometin
        Hi.
        TV: LG RZ42PX11
        Type: Plasma
        I have this old plasma that it's working fine. But it has a strange issue. If the picture is white, or has strong colors, it will flash and flicker. I attached a video showing the issue.
        What could cause that?
        Thank you....
        08-09-2020, 03:32 PM
      • Bloopeta
        Adjusting backlights Vestel - Laurus PH55CURVEUHD
        by Bloopeta
        Just a quick one, on this Laurus, if you go into the Picture menu to change settings, the Backlight adjust option is greyed out, I have had this before on other Vestel sets and cant remember what to do to 'ungrey it' so to speak...
        02-03-2020, 01:05 PM
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
      • dstanic
        Panasonic Plasma TH-50px600u blue haze (sparklies?)
        by dstanic
        I received this TV recently and very impressed with the picture quality. This set has no burn in however once the set is on for a little while it shows a blue haze when on a white or bright picture. The blue goes away when the picture goes darker or less white there will be less blue sparklies. When the TV is just turned on (cool) the picture is fine. Does it on either HDMI and i have a PC and a Chromecast and it will do it on both. On a bright picture with blue haze showing the tv also buzzes louder than normal through the speakers, unless i disable the speakers then no buzzing.
        02-09-2019, 01:10 PM
